Pull up bar in the middle of garden
mikeepps
Post by mikeepps »
Hi Everyone
Need help with the name of that steel tube with the fittings.
Any name of it, or where i can buy anything similar to that would be great help.
Im seriously dieng to work out and the gyms are closed.
Picture is in
Many Thanks
Mike
mikeepps
Post by mikeepps »
Has thanked: 823 times
Been thanked: 3560 times
You could fabricate using Key Clamp components https://keyclamphandrails.co.uk/
London mike 61
Has thanked: 285 times
Been thanked: 403 times
Post by London mike 61 »
If you search for steel tube handrail systems uk , you will get all the components you need.........if they are open of course!
Mike
mikew1972
Has thanked: 10 times
Been thanked: 110 times
Post by mikew1972 »
I made one out of a bit of scaffolding tube years ago. Probably slightly larger diameter but worked for me as I have large hands.
I made a v cut on top of the wood, drilled the pole and screwed down through the pole into the wood.
Or if you have the tools to make a large enough hole you could drill through the wood, slide the pole through and stop it sliding out by drilling a small hole through the pole then line it up and put a long screw or bolt through the wood and pole.
I'd say the bigger job would be securing the wood firmly enough into the ground.
Mike
