How to fill in hole in external wall
Posted: Thu Jun 11, 2020 8:28 am
by spr0ut
We had a new toilet fitted this week and the waste pipe needed adjusting. As a result, the old wast pipe is redundant but still in the wall. We therefore have a hole on the inside (which I can just fill with pollyfilla before decorating) and a hold on the outside brick wall.
Once I've removed the pipe, what is best to fill in the brick hole?
Posted: Thu Jun 11, 2020 8:55 am
by ayjay
If you have any matching bricks, chop out the old one (stitch drill the joint and then use a plugging chisel) and replace.
Posted: Thu Jun 11, 2020 9:00 am
by Someone-Else
If not a load of cement (and sand etc)
Posted: Thu Jun 11, 2020 10:13 am
by spr0ut
ayjay wrote: ↑Thu Jun 11, 2020 8:55 am
I don't unfortunately. Didn't know if there was just a simple filler to use? Should I try and fill the whole gap all the way through, or just at each end?
Posted: Thu Jun 11, 2020 10:24 am
by dewaltdisney
You can buy a small bag of mortar mix which will give you some cement to fill the hole. You can rub some brick dust on the surface as it is setting to disguise it a bit.
