tile adhesive and grout external
- etaf
- Has thanked: 38 times
- Been thanked: 154 times
Hi All
searched and read a few threads here,
but just wanted to ask again, as its an outside area fully exposed to elements, as west facing lot of sun in afternoon, and also we get lots of wind as we are near to the coast , and rain & salt etc into the porch
Rarely get snow , I think only had once in the 25 years and that was a sprinkle
Our outside porch tiling, which has been in place for over 25years (mother-in-law lived here before we purchased)
When it rains water always stays in the top right corner , quite a pool, brother-in-law sealed it all up years ago, so now I'm about to rip it all out , start again and also lay the tiles so they slope toward the path and not towards the door.
been a long while since i bothered to tile anything
The porch is West facing , and fills with leaves and rain all the time.
Wife has not yet chosen tiles, my questions are
Whats the best type of adhesive to use , no-nonsense from screwfix
https://www.screwfix.com/p/no-nonse...k ... _container
we had a lot of success with their no-nonsense products, stripper and filler
Grout , again best exterior use .
I will be taking all the panelling out , which is batterned to the wall and replacing
may post a different thread for that
image of porch attached
Tiles are 145mm across the top , so probably 150mm with a taper
I broke the tile yesterday hoping they may all come up and i could just relay, so now the jobs changed to a complete strip and start again, for the entire thing!!!!!
- 1 - 1.jpeg (233.3 KiB) Viewed 3858 times
Simple DIYer
Wayne
Wayne
- etaf
Just for completeness, I have now completed the job and heres the result
- 1 - 1.jpeg (99.55 KiB) Viewed 3732 times
Simple DIYer
Wayne
Wayne
- etaf
bad news tiles are lifting, noticed in Sept that the grout had cracked, and now today the tiles move!!!!!!
[MEDIA=youtube]RhfIOlWZ00E[/MEDIA]
no idea what went wrong
I'll lift in spring and see if i can see anything, meanwhile any ideas
Simple DIYer
Wayne
Wayne
- aeromech3
- Has thanked: 177 times
- Been thanked: 665 times
Shame, looked nice. Like a bath perhaps you needed to silicone seal around the edges (you used suitable waterproof grout as well) to stop the Westerly rain seeping in
- etaf
Yep, All waterproof flexible , BALI I think is the make, grout for internal & external use
Used Hippo Pro3 silicon, Would have used CT1 , but the yard had this stuff available and was finding materials difficult to get, and reviews showed Pro3 as good.
YEP all sealed round all the edges, and made sure NO water could get in , under the Marine Ply and the hardwood, Plastic above the tiles and step , all sealedLike a bath perhaps you needed to silicone seal around the edges
Simple DIYer
Wayne
Wayne
- Nik_Norcros
Silly question, did you prime the substrate before you tiled? What adhesive did you use and what grout did you go with?
- etaf
yes , i used Norcross Primer & Adhesive after talking to their support line in June , also used some Rapid concrete to lift an area, which they said
Cant remember the grout, its a Waterproof, flexible bal i think , MICROMAX 2 - for internal/external use.
Really good I emailed Norcross this morning, and had a response from the man in the area, agreed to look at in new year at my request , as i do not want a dangerous trip hazard area if they lift a tile
Simple DIYer
Wayne
Wayne
- Nik_Norcros
Has the tile come away clean from the adhesive or has the tile got the adhesive on the back but has lifted away from the substrate?
- Nik_Norcros
Sorry, just seen your previous post After i submitted my reply. Ignore my question. Im glad you got hold of some one to come out and take a look at it.
- etaf
https://youtu.be/RhfIOlWZ00EHas the tile come away clean from the adhesive or has the tile got the adhesive on the back but has lifted away from the substrate?
Simple DIYer
Wayne
Wayne
- Has thanked: 6 times
- Been thanked: 187 times
You will have to lift all the tile. Post a photo when the tile has been lifted.
You mention ply, where and how have you used ply?
Where you have a small brick riser then the outside corner should not be bare tile but a heavy duty edging.
