Cornice repair
SamRad
Cornice repair
Post by SamRad »
Hi guys
Hope you're all well.
Spot of DIY in the bedroom removing some fitted wardrobes. Unfortunately the installer must have damaged the coving.
Any recommendations on how best to go about repairing it? Putting jn free standing wardrobes so won't be covered. Photo attached.
Any tips much appreciated.
Sam
Has thanked: 831 times
Been thanked: 3630 times
Cornice repair
It is made with plaster of Paris which sets quickly. You need to form a shaper to get the profie just before it hardens. Have a look at this that gives you the basics https://www.youtube.com/watch?v=2_iU-rSuIjE
OnlineOnline
wes56
Has thanked: 6 times
Been thanked: 187 times
Cornice repair
Post by wes56 »
remove the remainder of the old wardrobe.
shape a piece of tin for a template of the moulding.
painters tape on the flat surfaces around the damage.
wet down the patch - a light dash of Pva will help.
mix a little gypsum(not skim) with a handful of cement to a soft mix. or just plaster no cement.
build up the missing bit in layers and let it just go proud.
run the template gently along to get the plaster profile.
as it firms up a light touch with damp sponge will smooth things out.
when dry sand smooth - including the old join ridges you can see.
Chop
Has thanked: 304 times
Been thanked: 219 times
Cornice repair
Post by Chop »
I've not used one myself for corniche but would one of those profile gauges that you see be any good in this situation?
Screenshot_20200715-075316_Samsung Internet.jpg (64.05 KiB) Viewed 1530 times
:thumbleft:
Return to “Plastering Forum”
