SDS drill
You can post and read reviews of all Power tools in here. Tools will be listed by manufacturer, Model number and / or description.please ensure that you put the correct power tool under the correct manufacturer. If the manufacturer is not yet listed then please post in the general part of the power tool review forum.
Has thanked: 47 times
Been thanked: 2556 times
SDS drill
My old mains SDS drill is showing its age and leaking grease (But I suspect that is because it got too hot in the sun) so I looked around and I now have.........
It came from screwfix, only had it a few hours, "tested it" just like you would expect, it didn't notice there is a wall in the way (Even when I tried the 18mm drill bit) I can't see me using it that often, so I only have the one (18v 4Ah battery) but I do have one particularly tough wall, odd thing is, it cost the same as my Dewalt hammer drill (Both were £150 each, not at the same time.)
It has a blow moulded case, which if like previous blow moulded cases will not last long, but we shall see.
But for the price, I am very happy.
Cannyfixit
Has thanked: 102 times
Been thanked: 183 times
SDS drill
Post by Cannyfixit »
I have had the same one one for over a year,it’s use is mainly for M12 rawlbolts and brown rawlplugs , no matter what the substrate is it goes in easy, I can’t fault it
Rorschach
Has thanked: 107 times
Been thanked: 1038 times
SDS drill
Post by Rorschach »
Looks good. I wouldn't buy cordless for an SDS myself as I don't use it often enough but if you are regular user it makes sense.
Dave54
Has thanked: 1300 times
Been thanked: 1175 times
SDS drill
Post by Dave54 »
I'm with Rorschach. Looks to be a good tool, but I don't use one enough to warrant going cordless.
Job and Knock
Old School Chippie
Has thanked: 742 times
Been thanked: 1573 times
SDS drill
Post by Job and Knock »
I went cordless (Makita 18 volt) 5 years ago. Sold my Bosch 2kg corded SDS within months. I'll not say that there haven't been occasions when I haven't needed a larger SDS drill - but they have been few and far between and pretty much every instance has been one where I was using rotation stop (for chipping, chiselling and breaking out masonry), and even then in most cases the cordless has been good enough to do that, too
Return to “Power Tool Reviews”
