Nissan Almera Service Warning
yellowlab_2
Post by yellowlab_2 »
I have a 2005 Nissan Almera and when I turn on the ignition a warning sign comes up on the screen stating that a service is due, does anyone know how I can remove this warning.
yellowlab
village idiot
diesel demon
Has thanked: 104 times
Been thanked: 104 times
Post by village idiot »
maybe get it serviced :scratch:
i love being married
I have a soft spot for the wife, it's a peat bog just outside Ardross
Still Yes Highland
Welsh Decorator
Been thanked: 4 times
Contact:
Post by Welsh Decorator »
If it's anything like the old Rover 800's, you just remove the alternater fuse for 10 / 20 seconds.
Not 100% certain if Nissan will be the same? :scratch:
I wish I was born rich..............instead of just good looking!!!
Only-Me
Been thanked: 3 times
Post by Only-Me »
Take the bulb out :wink:
Raf
Has thanked: 1 time
Post by Raf »
look at your manual it may tell you but some cars need a computer plugging into the obdII port to reset (can be done by shorting 2 points on the obdII port too).
on citreons and others you hold the milegae reset button and switch on ign.... usually a simple sequence.... try google if all else fails.
Hoovie
Borders Bodger
Post by Hoovie »
You can also buy a ODBI II box for about £25 and read/reset all the codes - very handy if you either do your own servicing or want to make sure the garage isn't telling porkies about a failure.
Case in point - Mate has a Saab convertible and roof has failed - quoted £1300 to repair - Hydraulic lifters failed, etc.
Report from ODBI said switch had failed - got new switch fitted.... £125
EJJ150847
Has thanked: 35 times
Been thanked: 188 times
Post by EJJ150847 »
Have a look on the Almera owners club website, I belong to the Volvo Owners club and there is good advice on these sites.
John
yellowlab_2
Hello,
Thanks for the replies. I managed to find the answer on another site and the warning notice has now been removed.
I am interested in the ODB1 11 box, sounds a useful bit of kit, where would you be able to purchase one of these.
yellowlab
Hoovie
Borders Bodger
Post by Hoovie »
You can buy these for less then a garage will charge to plug one it and tell you the codes - use your own, plus the last link inthis post and you can tell the garage what is wrong :thumbright:
Various suppliers - here is an example ....
GS100 Geniscan OBD-II Fault Code Reader
and an old eBay Listing ....
UNIVERSAL CAR DIAGNOSTIC SCANNER CODE READER OBD2 + CAN
and a bit of general info to help decode what it tells you ....
OBD-II Trouble Codes
If your car is later then about 2002(ish) then by law, it has to have an OBD-II / CAN port. Many cars before that date have them also.
If you buy one, post back what you think :thumbright:
yellowlab_2
Hello Hoovie
Thanks for the info. I have a 2005 Almera so it should work on mine. I am only a very amateur car mechanic and hope with the age of my car I wont require the use of one of these. I will try and interest my youngest son whose a bit more into this than I am. If I do get one ( none on ebay at present) I'll let you know how I get on.
yellowlab
