Your opinion on kitchen units
yartin
Has thanked: 145 times
Been thanked: 129 times
Post by yartin »
My kitchen units were delivered 3 days ago, several of the item have dents or poorly finished. What do you think?
twwr15 pic2.jpg (21.29 KiB) Viewed 3451 times
twwr15 pic1.jpg (32.96 KiB) Viewed 3451 times
tb836-1 pic2.jpg (32.96 KiB) Viewed 3451 times
tb836-1 pic1.jpg (70.14 KiB) Viewed 3451 times
tb536-1 pic2.jpg (31.06 KiB) Viewed 3451 times
tb536-1 pic1.jpg (31 KiB) Viewed 3451 times
yartin
Post by yartin »
Another pic of base unit, how poorly is that assembled?
base unit1.jpg (23.69 KiB) Viewed 3442 times
adonis
Has thanked: 30 times
Been thanked: 121 times
Post by adonis »
That looks poor quality to me, if you was fitting that for a customer they wouldn't be pleased, where did they come from?
Every time I order conti board for shelves they always have chips.
Scotty001
Has thanked: 26 times
Been thanked: 174 times
Post by Scotty001 »
Likewise they are in poor condition, as a customer I would not be happy receiving those.
With that amount of exposed / damaged chipboard it will soak up any spilt liquid like a sponge and blow out, you'll be buying another new kitchen in a few years if that.
I think I know who your quality checker was
Think of it as you've just bought a new car, the dealership drops it off with dents in the doors, scratches in the paintwork and a crack in the window screen. Would you be happy to accept your brand new car in that condition?
arco_iris
Has thanked: 184 times
Been thanked: 535 times
Post by arco_iris »
That looks poor quality to me, too - but, one tends to get what one has paid for, I suspect.
If from a known brand, definitely worth complaining - good manufacturers have a reputation to maintain and will replace without quibble. Though looks like you might be needing some luck in that regard.
yartin
Post by yartin »
Yes poor quality and pretty bad overall. That base unit, how would you fit a worktop?!
I sent an email asking the supplier to collect and refund but haven't heard yet, early days. I spoke to my credit card, they said I shouldn't have a problem and they will come in if needed.
And as for the manufacturer, I am tight lipped atm and no it wasn't cheap at all. But unfortunately I went for it because of a couple of strong recommendations from a forum, and from this forum! Disappointed.
yartin
Post by yartin »
arco_iris wrote: Mon May 17, 2021 2:15 pm
Almost all carcasses are like that, I am not bothered to check doors and panels, still in the packaging, not opening them. Why would I be needing luck? I asked supplier to collect and refund, credit card said that's what has to be done.
Thesecondfavourite
Has thanked: 1 time
Post by Thesecondfavourite »
Have you got a pic of the expected unit with the door finish, I have ordered my kitchen from an online company which I've read excellent reviews about also. What finish/door style did you go for? Thanks
Has thanked: 740 times
Been thanked: 2355 times
the biggest problem you have is not so much you have a chips missing or a gaps that are both mostly unacceptable it more importantly means its not sealed so an easy path for damp and wet to delaminate the joint then structure
OnlineOnline
yartin
Post by yartin »
Thesecondfavourite wrote: Mon May 17, 2021 8:07 pm Have you got a pic of the expected unit with the door finish, I have ordered my kitchen from an online company which I've read excellent reviews about also. What finish/door style did you go for? Thanks
I was expecting clean cuts no chips no stains on carcases or doors. Worktop won't fit flat on one of the base units. One unit has standard hinge when all units ordered with soft close. 80% of the units have problems.
Where did you order from?
Thesecondfavourite
Has thanked: 1 time
I went to DIY Kitchens and have ordered the handleless luca range, soft close hinge/runners too
Chippo1
Has thanked: 10 times
Been thanked: 194 times
Post by Chippo1 »
I fitted DIY stuff 2 ½ years ago no issues like these , also recently installed some more in kitchen to go around American style fridge , again no problems other than they didn’t do a top box that worked for me. It was Luca handle less in Farrow and ball blackened , with oval room blue trims. No knocks , Knics or Chips any where on delivery , I caused a couple of minor ones but they supplied touch up paint.
arco_iris
Post by arco_iris »
Several aspects in the the pictures cause me to suspect it's not from DIYK.
yartin
Post by yartin »
They sent driver today, all items returned.
I had to wait for 2 months for delivery, luckily I have a kitchenette to use.
So tired of this, I have to start looking again, any strong recommendations? :lol:
On serious note, I will have a look at Wren and Ikea and even B&Q...
fin
Has thanked: 32 times
Been thanked: 816 times
Post by fin »
i did a diyk earlier this year/ late last year. nowt like this.
i did do a kitchen from a local place which was a bit of a pain in the arse. the film on the gloss panels was a nightmare full of scratches that didnt go through to the actual final surface..... but did make the peeling off a nightmare, it was also full of scuffs etc. hopfully that was a one off though.
Return to “Kitchen Fitting”
