Like the title says, is it possible to cut solid laminate with a jigsaw and achieve a clean cut?
I'm just a DIYer, no experience in this area at all.
I will need to make it shorter and narrower and make a cut-out for the column.
The edges I cut will be going against the walls so it doesn't have to be 100% perfect I suppose but got to be good enough. Maybe a bit of imperfection could be masked with some dark sealant applied into the gap between the wall and the worktop?
If it can be done which type of blade should I buy for the jigsaw? Or is the material going to be too tough and should be done with a different tool?
