Changing Rear Discs
Argonaut
Has thanked: 6 times
Changing Rear Discs
Post by Argonaut »
I need to change Rear Disc & pads on my Kodiaq.
Found good videos on steps (as it has EPB)
Need to change:
2 x Rear Disc
2 x Torx 30 csk fixing screws
2 pairs pads
2 pairs pad clips / anti-rattle springs
2 pairs calliper fixing screws
2 pairs carrier frame fixing screws
Anybody know if I can buy these as a kit .... workshop video say to change screws & springs, and show kit with all parts, but so far supplier (Europarts etc) seem to just have pads & discs nothing else.
Has thanked: 831 times
Been thanked: 3626 times
Changing Rear Discs
There seems to be an issue with Kodiaq rear brakes. I just had a quick look and this site seems to have all the gear which might be worth checking https://www.autodoc.co.uk/car-parts/bra ... 25-2-0-tdi Also you might want to try the Kodiaq forum https://www.kodiaqforums.co.uk/viewtopi ... 2d3f27cc43
I do not know if there is a compatability with VW or Seat parts?
OnlineOnline
Argonaut
Changing Rear Discs
Post by Argonaut »
Seems to be poor quality of discs …
I will probably go with Brembo … discs & pads for £80
Changing Rear Discs
Yes, I agree the Bembro brakes are excellent.
OnlineOnline
Argonaut
Changing Rear Discs
Post by Argonaut »
Sorry about typo .. almost correct :-)
Argyll
Has thanked: 1191 times
Been thanked: 583 times
Changing Rear Discs
Post by Argyll »
I almost never change the screws etc. If they're in good nick.
Make sure and smear copper slip over the rear of the brake pad and use brake cleaner to degrease the disc.
Make sure you don't have a hangover and put a pad back to front as I did many years ago 😒
Nos
Has thanked: 3 times
Been thanked: 80 times
Changing Rear Discs
Post by Nos »
Reminded me of a tale in the late Murry Walkers biography, he was invited as a guest of British Leyland to look at the New Morris Marina production line, after a nice tour he looked across at where the wheels were being fitted and noticed at the front there was a disc brake and on the same axle ie the opposite side, there was a drum brake fitted :lol: :lol:
