Oven - element fault
Kabous
Has thanked: 7 times
Been thanked: 3 times
Post by Kabous »
Hello All
Just fitted a new top element to a Bosch oven as the previous inner ring was not working. The new element shows same fault so I suspect the fault is elsewhere. Check wiring and connectors at back when doing fitting of new element and all seems well.
Your advice to find the fault or doing some testing greatly appreciated.
London mike 61
Has thanked: 285 times
Been thanked: 403 times
Post by London mike 61 »
You are better off asking your question in the uk whitegoods forum because they deal with stuff like this on a daily basis.
https://www.ukwhitegoods.co.uk/forums
Mike
These users thanked the author London mike 61 for the post:
Kabous (Wed Nov 24, 2021 5:51 pm)
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
Sure that inner element isn't for the GRILL setting?
Kabous
Post by Kabous »
@kellys_eye, yes inner ring is for grill and pic was taken with oven on grill setting.
kellys_eye
It's the grill SWITCH then.
Return to “Electric Forum UK”
