How to Remove Rust Faster?
ugoleaf
Has thanked: 120 times
Been thanked: 4 times
Post by ugoleaf »
Hello,
Sitting here, trying to restore old ruler with 800 grit grade sandpaper but it's very slow. Any way to make the process more effective?
wine~o
Has thanked: 1415 times
Been thanked: 4030 times
Post by wine~o »
baking soda mixed with vinegar, mix to a paste apply and polish off with a cotton cloth. Risne and dry after.
ugoleaf (Sat Dec 04, 2021 5:44 pm)
ugoleaf
Post by ugoleaf »
wine~o I read that wiping with sandpaper and WD40 can work. Your opinion?
wine~o
Post by wine~o »
Wet and dry might work with WD 40, can't say I've ever tried though.
ugoleaf (Sun Dec 05, 2021 1:14 pm)
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Post by aeromech3 »
For steel phosphoric acid which is usually what is used in car de rust solutions and gels from the likes of Halford's, I still have a bottle of Navy Jelly from my Austin days, but heavy rust does turn black and this is not used on Stainless Steel which I suspect your ruler might be. However if you are a Coca-Cola fan and want to give it a try, as there is a food grade of this acid in fizzy drinks, you might try dunking in Cola.
ugoleaf (Sun Dec 05, 2021 1:13 pm)
Rorschach
Been thanked: 1043 times
Post by Rorschach »
I use citric acid for my rust removal these days (assuming I can easily immerse the item).
It's very cheap, very safe and works well. I mix it with HOT water and soak the item for a few hours, depending how bad the rust is. A scrub with a stiff brush every half hour helps if it's a thick layer of rust.
After it's clean I dip in a bicarb solution to neutralise any remaining acid (though it doesn't tend to attack non rusted metal), dry it really well and then oil.
These users thanked the author Rorschach for the post (total 2):
ugoleaf (Sun Dec 05, 2021 1:15 pm) • ahfix (Sun Dec 05, 2021 2:15 pm)
Rating: 14.29%
Grendel
Has thanked: 201 times
Been thanked: 522 times
Post by Grendel »
ugoleaf wrote: Sat Dec 04, 2021 5:45 pm wine~o I read that wiping with sandpaper and WD40 can work. Your opinion?
I've used wet and dry paper with brasso and that seemed to work better than just the sandpaper on it's own.
These users thanked the author Grendel for the post:
ugoleaf
Post by ugoleaf »
Rorschach wrote: Sun Dec 05, 2021 7:57 am After it's clean I dip in a bicarb solution to neutralise any remaining acid (though it doesn't tend to attack non rusted metal), dry it really well and then oil.
I have citric acid powder. Do you oil with WD40 or sewing machine oil or car oil? I have former two but not car oil.
Rorschach
Post by Rorschach »
ugoleaf wrote: Sun Dec 05, 2021 1:18 pm
Depends on the item, any of them will be fine but some things I don't want too oily, so for instance a drill chuck I would use a heavier oil, a ruler would only be some wd40.
ugoleaf
Post by ugoleaf »
Rorschach I will just spray WD40 on kitchen paper towel and wipe?
Rorschach
Post by Rorschach »
Yep that'll work
Has thanked: 740 times
Been thanked: 2355 times
as this is the front grill on the computer, you need to be really really careful that nothing goes inside that may cause damage assuming the same grill :lol:
viewtopic.php?f=24&t=105850&p=849541#p849541
Has thanked: 48 times
Been thanked: 2604 times
big-all wrote: Sun Dec 05, 2021 10:45 pmas this is the front grill on the computer
I thought he said (in this post) he wanted to clean his steel rule?
Someone-Else wrote: Sun Dec 05, 2021 11:16 pm
yes indeed it could be but just checking incase as a computer grill is involved
its just very unusual to get 2 rust removal posts from the same person at the same time :lol:
if it is a ruler please ignore my comments :huray:
ugoleaf
Post by ugoleaf »
big-all wrote: Mon Dec 06, 2021 12:04 am its just very unusual to get 2 rust removal posts from the same person at the same time :lol:
I am Anti-Rust superhero.
These users thanked the author ugoleaf for the post:
big-all (Mon Dec 06, 2021 9:30 am)
