Papering a plasterboard wall
Argyll
Has thanked: 1194 times
Been thanked: 584 times
Post by Argyll »
I need to put lining paper on an unskimmed plasterboard wall. How should I prepare it?
arco_iris
Has thanked: 184 times
Been thanked: 535 times
Post by arco_iris »
Use paper drywall tape over board joints, not scrim tape. Apply Plasterboard Joint Compound over the tape, if necessary more than one layer, and also over screw heads. Sand down the compound gently when perfectly dry so as not to dig up the board surface. Size the entire wall with weak wallpaper paste and allow to dry. Apply lining paper in usual way.
Alternatively use Wallrock, Erfurt or similar HD lining papers.
These users thanked the author arco_iris for the post:
Argyll (Fri Mar 11, 2022 9:48 am)
Argyll
Post by Argyll »
It's already been filled and sanded mate. I know you're not meant to paper straight onto bare plasterboard. I just couldn't remember how.
Cheers
