Page 1 of 2
FAULT WITH SWITCH AND SOCKET
Posted: Thu Mar 17, 2022 2:45 pm
by teams
HI Guys
We have three issues:
a) the 13 amp spur switch is news but isn't working (red square),
b) the extractor fan is new, worked before the new 13 amp spur switch was installed,
c) the 2 gang socket worked, but has stopped working (green square).
Black squares are 2 gang sockets, all new, which all work.
Any help much appreciated.
Many thanks.
- FAULT WITH SWITCH - SOCKET.png (15.76 KiB) Viewed 1595 times
Posted: Thu Mar 17, 2022 3:15 pm
by Someone-Else
That's nice.
Since the "spur" is new I would have to guess it has been wired wrong, or connected wrong. Picture of connections would help. (Turn the mains off first.)
Posted: Thu Mar 17, 2022 5:02 pm
by Neelix
Get the person who made the changes to fault find?
Posted: Thu Mar 17, 2022 5:25 pm
by teams
Someone-Else wrote: ↑Thu Mar 17, 2022 3:15 pm
That's nice.
The first one is from below, the second one is from above.
Posted: Thu Mar 17, 2022 5:35 pm
by Someone-Else
You can not be serious?
What is with the rubber bands?
I am not going to mention the amount of copper I can see.
Teams, I assume you do not see what is wrong?
Get the person who did it back.........................unless it was you, was it? (we all make mistakes)
Posted: Thu Mar 17, 2022 5:52 pm
by wine~o
teams, Looks to me like that black wire (neutral) with the copper showing isn't actually connected. As S-e says that's an amateur job.
Posted: Thu Mar 17, 2022 7:28 pm
by teams
Someone-Else wrote: ↑Thu Mar 17, 2022 5:35 pm
Yes it was me, I'll have a go tomorrow. All but two of the wires are really rigid, the problem is also the new switch / socket, the bit which holds the screws tilts (a design feature).
Posted: Fri Mar 18, 2022 3:01 pm
by teams
This is the old Spur Switch, picture taken before removing - the instructions for the new switch state that it's a case of wiring it the same.
- 20220302_153504.jpg (138.56 KiB) Viewed 1540 times
Posted: Fri Mar 18, 2022 3:38 pm
by Someone-Else
teams wrote: ↑Fri Mar 18, 2022 3:01 pmthe instructions for the new switch state that it's a case of wiring it the same
Yes, they probably do, but you didn't.
We all learn from our mistakes.
You need to make the connections on your new FCU look like the connections on your old FCU. You picture clearly shows the black wire is not connected properly.
Posted: Fri Mar 18, 2022 4:47 pm
by wine~o
Someone-Else wrote: ↑Fri Mar 18, 2022 3:38 pm
That's what I said.
Posted: Fri Mar 18, 2022 5:41 pm
by teams
I think 'wiring it the same way is incorrect, simply because the switch is 'colour coded', I noticed that when I was doing it, but followed there 'do it the same way'.
Below is the diagram.
- wiring.JPG (18.98 KiB) Viewed 1531 times
Posted: Fri Mar 18, 2022 5:43 pm
by Someone-Else
But you still have the copper wire exposed.
Posted: Sat Mar 19, 2022 12:12 pm
by teams
Still no joy, used colour codes on diagram / switch. As below
These are the cables that need to be wired to the switch:
Cable 1 - Brown and Blue,
Cable 2 - Red, Black and Green / Yellow (I've just used green in the diagram)
Cable 3 - Red, Black and Green / Yellow (I've just used green in the diagram)
- switch 112.JPG (44.76 KiB) Viewed 1504 times
Posted: Sat Mar 19, 2022 12:32 pm
by Neelix
Is this a ring or a radial ?
Posted: Sat Mar 19, 2022 12:47 pm
by teams
Neelix wrote: ↑Sat Mar 19, 2022 12:32 pm
Radial, drawing in first post.
