FAULT WITH SWITCH AND SOCKET
teams
Has thanked: 119 times
Post by teams »
HI Guys
We have three issues:
a) the 13 amp spur switch is news but isn't working (red square),
b) the extractor fan is new, worked before the new 13 amp spur switch was installed,
c) the 2 gang socket worked, but has stopped working (green square).
Black squares are 2 gang sockets, all new, which all work.
Any help much appreciated.
Many thanks.
FAULT WITH SWITCH - SOCKET.png (15.76 KiB) Viewed 1583 times
Has thanked: 47 times
Been thanked: 2575 times
That's nice.
Since the "spur" is new I would have to guess it has been wired wrong, or connected wrong. Picture of connections would help. (Turn the mains off first.)
teams (Tue Mar 22, 2022 6:17 pm)
Neelix
Has thanked: 117 times
Been thanked: 214 times
Post by Neelix »
Get the person who made the changes to fault find?
These users thanked the author Neelix for the post:
teams
Post by teams »
Someone-Else wrote: Thu Mar 17, 2022 3:15 pm That's nice.
The first one is from below, the second one is from above.
You can not be serious?
What is with the rubber bands?
I am not going to mention the amount of copper I can see.
Teams, I assume you do not see what is wrong?
Get the person who did it back.........................unless it was you, was it? (we all make mistakes)
wine~o
Has thanked: 1414 times
Been thanked: 4019 times
Post by wine~o »
teams, Looks to me like that black wire (neutral) with the copper showing isn't actually connected. As S-e says that's an amateur job.
teams
Post by teams »
Someone-Else wrote: Thu Mar 17, 2022 5:35 pm You can not be serious?
Yes it was me, I'll have a go tomorrow. All but two of the wires are really rigid, the problem is also the new switch / socket, the bit which holds the screws tilts (a design feature).
teams
Post by teams »
This is the old Spur Switch, picture taken before removing - the instructions for the new switch state that it's a case of wiring it the same.
teams wrote: Fri Mar 18, 2022 3:01 pmthe instructions for the new switch state that it's a case of wiring it the same
Yes, they probably do, but you didn't.
We all learn from our mistakes.
You need to make the connections on your new FCU look like the connections on your old FCU. You picture clearly shows the black wire is not connected properly.
teams (Tue Mar 22, 2022 6:18 pm)
wine~o
Post by wine~o »
Someone-Else wrote: Fri Mar 18, 2022 3:38 pm
That's what I said.
teams
Post by teams »
I think 'wiring it the same way is incorrect, simply because the switch is 'colour coded', I noticed that when I was doing it, but followed there 'do it the same way'.
Below is the diagram.
But you still have the copper wire exposed.
teams
Post by teams »
Still no joy, used colour codes on diagram / switch. As below
These are the cables that need to be wired to the switch:
Cable 1 - Brown and Blue,
Cable 2 - Red, Black and Green / Yellow (I've just used green in the diagram)
Cable 3 - Red, Black and Green / Yellow (I've just used green in the diagram)
switch 112.JPG (44.76 KiB) Viewed 1492 times
Neelix
Post by Neelix »
Is this a ring or a radial ?
teams (Tue Mar 22, 2022 6:19 pm)
teams
Post by teams »
Neelix wrote: Sat Mar 19, 2022 12:32 pm Is this a ring or a radial ?
Radial, drawing in first post.
Return to “Electric Forum UK”
