Landline is dead
Telecommunications, Broadband and networking questions in this forum please
Distorted Vision
Has thanked: 4 times
Been thanked: 7 times
Landline is dead
Post by Distorted Vision »
My BT landline is dead. We have a BT NTE5 Master Socket. I've disconnected the faceplate and connected a phone into the test socket.
Still dead. It won't receive incoming calls.
Is there anything else I can try? BT charge £85 for an engineer's visit.
Many thanks!
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Landline is dead
Post by kellys_eye »
BT don't charge unless the fault is inside the users premises i.e. something that 'you' did. Report the fault and let them fix it.
Has thanked: 831 times
Been thanked: 3627 times
Landline is dead
Can you do a line test using your mobile? https://www.bt.com/help/broadband/run-a-line-check/
OnlineOnline
Distorted Vision
Landline is dead
I don't have broadband with BT only a landline. I called from my mobile and did an automated line test which passed, hence my original post.
Has thanked: 48 times
Been thanked: 2604 times
Landline is dead
The BT landline test should not be relied upon, as you have proven. BT will always say there is a charge because they often get called out for "silly things" As kellys_eye said they will charge you IF the fault is on YOUR side of the socket, call them, there is nothing else you can do.
Distorted Vision
Landline is dead
Logged the fault by SMS and engineer aim to fix by Thursday 24th March.
IRS_Plat
Landline is dead
Post by IRS_Plat »
BT are supposed to charge for internal faults, however open reach changed our master socket which had corrosion on the connections which was causing a similar fault. Befriend the engineer with a cup of tea.
Landline is dead
IRS_Plat wrote: Wed Mar 23, 2022 11:03 amBT are supposed to charge for internal faults, however open reach changed our master socket which had corrosion on the connections which was causing a similar fault.
Sorry to say, but that is not true.
The BT master socket, belongs to BT, any problems with it, you do not pay. Yes cups of tea do go down well with all trades, but it did nothing regarding not receiving a bill.
EJJ150847
Has thanked: 35 times
Been thanked: 188 times
Landline is dead
Post by EJJ150847 »
IDo you have a voltmeter and know how to use it? Remove the faceplate of the master socket with nothing connected at the two cables coming in from BT there should be around 50volts dc, normally B is positive A is negative. If there is voltage present fault is probably your wiring!
Landline is dead
EJJ150847 wrote: Wed Mar 23, 2022 9:47 pmDo you have a voltmeter and know how to use it? ...........there should be around 50volts dc
Sorry, what is the point of that?
Distorted Vision wrote: Sun Mar 20, 2022 10:21 pmMy BT landline is dead. I've disconnected the faceplate and connected a phone into the test socket.Still dead
We already know the line is dead, and you can have voltage on the line but no tones. (Seen that on quite a few occasions)
Distorted Vision
Landline is dead
I called BT and they confirmed that there is a disconnect on my line. Fix estimated to be complete by tomorrow.
Distorted Vision
Landline is dead
BT engineer visited yesterday. Our new neighbours are having a block paving driveway installed and the workers have accidentally damaged BT's cable and its affected 3 neighbouring properties as well.
Landline is dead
Good to hear the outcome :thumbright:
OnlineOnline
Return to “communications and broadband”
