tapering ceramic tiles odd shape
finest1
Has thanked: 31 times
Been thanked: 5 times
Post by finest1 »
hi all.
i'm planning to relay some border tiles on my shower tray. the shower tray is not flush level and has a taper to it. so when you put straight tiles the grout lines start thin on one end, gets larger, then tapers off, like a bow. my intial thoughts was to try and taper cut the tiles. i have a wet tile cutter with a fixed blade. been having issues tapering the cuts. i was practicing with some off cuts today to see if i can get something looking good. has anyone any tips on getting a good taper?
thanks
finest1
Has thanked: 807 times
Been thanked: 3496 times
In the past I scored the line and nibbled it off with pincers. Now I would make a temporary fence guide using wood and hand clamps on my tile saw.
finest1
Post by finest1 »
hey DWD! thanks for the swift reply. i don't have any nippers or tile cutters, just a scribe. the tile is glazed for the scribe just skids off. i have enough tiles left for the job in hand, i don't want to waste tiles by making mistakes thanks
I have cut slivers off tiles on my saw. I am sure a tapered fence will do the trick :thumbright:
finest1
Post by finest1 »
ive never heard of a fence guide, have you any vids or online resources. i've tried googling it, but fencing work comes up!! i'm sure thats not it!!
The fence is the guide bar on the table of your electric tile cutter, it has just occurred to me that you might not have one and you only have a manual one. An electric one is not that expensive see https://www.screwfix.com/p/performance- ... 240v/469gt take the guide off and replace it with a strip of wood clamped at an angle to guide your tile. I can see that you would not want to do £50 for a few cuts, can you borrow one?
Has thanked: 734 times
Been thanked: 2333 times
dewaltdisney wrote: Thu Sep 15, 2022 4:05 pm I have cut slivers off tiles on my saw. I am sure a tapered fence will do the trick :thumbright:
tapered fence as such wont work unless you mean a sliding angle guide ??
if you can get the first one cut accurately, you can use the off cut against the fence and push through with the tile to present the tile at the correct angle adjusting the fence position iff necessary to give the exact same width off tile
It is the fence angle to the blade that determines the cut line, the straight edge of the tile follows the fence and the blade cuts the angle on the opposite edge. I have a similar jig on my table saw for cutting tapered legs.
not familiar with tile saws as such do they have a carriage to transport the tile in a parallel line but sitting at an angle or a blade moving in a slicing motion like a mitre saw :dunno:
finest1
Post by finest1 »
dewaltdisney wrote: Thu Sep 15, 2022 8:39 pm The fence is the guide bar on the table of your electric tile cutter, it has just occurred to me that you might not have one and you only have a manual one. An electric one is not that expensive see <span class="skimlinks-unlinked">https://www.screwfix.com/p/performance- ... 69gt</span> take the guide off and replace it with a strip of wood clamped at an angle to guide your tile. I can see that you would not want to do £50 for a few cuts, can you borrow one?
oh, i see! yes, i have a manual guide. i did try that approach at first, but the tile kept reverting to a stright cut i was fighting against the stationary blade. should i have been firmer in my approach?
Yes, your focus is holding the tile tight against the guide and feeding slowly to let the blade cut at its rate to avoid snatch. Tape and mark the cut line, it is easier to see during cutting. Use gloves for grip.
big-all (Fri Sep 16, 2022 9:57 am)
etaf
Has thanked: 37 times
Been thanked: 146 times
Post by etaf »
i borrowed a small table saw , from brother-in-law - pretty much the same as they sell at toppstile and screwfix/toolstation for around £50
I did purchase a new 110mm blade for it , hes was from B&Q , but pretty much identical
https://www.toppstiles.co.uk/fixing-fin ... utter-450w
But i was cutting quite a few tiles - so easy to do - and i also cut a taper by doing exactly as described , fitted a bit of wood with clamps , although the guide it had was OK
Also you need to make sure the taper is the correct way - so you dont jam the blade by mistake
the one i had was very messy and water etc went everywhere - but that seems to be the feedback for all of them , so do make sure you do it outside , I did mine on a lawn
Simple DIYer
Wayne
Yes they are messy the coolant water and tile dust form a sludge, I laid out some plastic sheets on my garage floor which made clean-up easier. I could have cut Finest's tiles quicker than writing this :lol:
etaf
Post by etaf »
dewaltdisney wrote: Fri Sep 16, 2022 10:25 am I laid out some plastic sheets on my garage floor which made clean-up easier
yep, i should have done that , as you say all the dust & sludge and some small bits of tile - at least the bit of ground i used was nolonger going to be lawn and not cut with a lawnmower which would not have done the blades much good
Simple DIYer
Wayne
:lol: :lol:
Return to “Tiling Forum”
