Slow set adhesive for large wall tiles
Posted: Tue Nov 22, 2022 7:03 pm
I have got some 30cm x 90cm tiles i want to DIY on the new shower enclosure.
Although I have done tiling a few times before with good results in the past ,since its my first time with large tiles i want to be a little less stressed in terms of adhesive pot life if i can :)
Is there such slow setting adhesive that can be used on these tiles ? All i could find is fast and standard setting stuff .
Tiles are around 8mm rectified and ceramic . They weigh around 5.5kg each which is not so heavy i dont think for the size.
The base is made of STS 10mm foam board which does not require any priming etc
many thanks in advance
