External rendered steps? Strengthen?
orangepeel
Has thanked: 6 times
Been thanked: 2 times
Post by orangepeel »
Morning all
We have various low external walls that merge with steps to the upper part of our split level garden.
Don't shoot me down here but Is there anyway we can render the walls and steps including the top of the treads? I know it won't have much compression/impact strength however, it will only get low foot traffic.
It's all constructed out of concrete block work and essentially we want the final look to be a little like cast concrete and we really dislike the look of coping on walls. I was going to give it a try with Tarmac OCR.
Could we add anything to the mix going on the treads to help? An additive, additional aggregate or even something like small gravel?! Would it be mad to install beading with the face in render then essentially a concrete mix on the treads?!
Thanks and I apologise if this seems ridiculous :lol:
Cheers all.
Has thanked: 831 times
Been thanked: 3627 times
For the steps, I would investigate resin bound gravel type finishes. It is tough, anti slip and gives you a degree of colour variation depending on the gravel selected. As for coping there is a reason for a cap and that is to prevent water ingress and expansion damage in sub zero temperatures. Have you seen road potholes lately?
OnlineOnline
orangepeel
That's an idea for the steps!
Looked at resin for things before but not thought about the steps.
Fully get the reason for coping but you do see so much where water has penetrated the mortar joints and caused water marks down the face of the walls. I just want to explore alternatives before I commit.
Thanks for the help.
arco_iris
Has thanked: 184 times
Been thanked: 535 times
Post by arco_iris »
Lay paving slabs cut to size on the steps, even ceramic or quarry tiles, these could be second-hand.
Add waterproofer to the render, e.g. Feb Rendamix or Febproof, there are other brands available.
APDIY
Has thanked: 387 times
Been thanked: 37 times
Post by APDIY »
Any possibility of some pix, plz?
I may have the same project to address.
T Y
Has thanked: 740 times
Been thanked: 2355 times
render on treads is not pet or child friendly so iff you have grandchildren or pets :scratch:
OnlineOnline
orangepeel
APDIY wrote: Sat Mar 25, 2023 12:40 pm Any possibility of some pix, plz?
T Y
Sorry for the late reply, work took over.
Here's a pic.
[/img]
These users thanked the author orangepeel for the post:
APDIY (Mon Apr 03, 2023 8:15 am)
There's a degree of practicality as well as aesthetic appearance needed here. I would use the slabs and cut sections to fit the steps so you get a uniformity. You can stick a non slip strip on the step edges for safety when wet. I would continue the cut the slabs to make sections for coping stones for the rest to make the look inclusive. You want it to look nice not a mish mash of styles.
OnlineOnline
APDIY
Post by APDIY »
dewaltdisney wrote: Sun Apr 02, 2023 9:04 am . You can stick a non slip strip on the step edges for safety when wet.
Some non slip strip is just what may solve one of my problems. Details, please?
You can get a roll of anti slip tape external use for £12 to £20 on Amazon. It will normally stick well onto most smooth surfaces. I put some on a relative's quarry tiled step and it has worked very well preventing slips.
APDIY (Mon Apr 03, 2023 6:17 pm)
OnlineOnline
Return to “Plastering Forum”
