Toaster tripping the circuit
hiace_drifter
Has thanked: 29 times
Been thanked: 16 times
Post by hiace_drifter »
My 3 month old toaster has started tripping the consumer unit, but only when used at one particular socket. I have used microwave/kettle/drill at the same socket and all is fine. I have used the toaster at other sockets and all is fine. I will take a picture of the "rcd" or whatever that is tripping (it is not for the specific circuit, it is for the whole side of the board). Is it a problem with the socket that is being exposed by the way the toaster draws current?
Has thanked: 47 times
Been thanked: 2575 times
If the RCD (I assume it is an RCD) trips when the toaster is used in a specific socket, I would suspect the socket.
Try the toaster in say, the lounge, anywhere but the kitchen, what happens?
Plug something else high current in this socket, kettle, blow heater, hair dryer. What happens?
EJJ150847
Has thanked: 35 times
Been thanked: 188 times
Post by EJJ150847 »
This happened to someone I know the toaster was full of breadcrumbs. I told her to empty all the breadcrumbs out of the toaster after every use.
These users thanked the author EJJ150847 for the post:
Neelix (Mon Apr 17, 2023 3:50 pm)
ericmark
Has thanked: 116 times
Been thanked: 783 times
Post by ericmark »
I found with multi circuits on one RCD it was hard to work out which item is really the problem. With neutral to earth faults any item drawing current can trigger a trip actually caused by another item.
So first thing is unplug anything not used, second is do you know anyone with an insulation tester
these test at 500 volt so can work out what is the real problem item, or a clamp on ammeter
Testing for live.jpg (82.7 KiB) Viewed 745 times
these can show the total earth leakage, it is possible the toaster is just pushing the total over the edge.
Both cost around £35 but need some skill to use them.
It seems likely from what you say it is an earth - neutral fault.
Neelix
Has thanked: 117 times
Been thanked: 214 times
Post by Neelix »
I guess the obvious question is has any DIY work been done in the kitchen recently ?
Has thanked: 818 times
Been thanked: 3514 times
Currys do a cheap toaster to use as a test https://www.currys.co.uk/products/essen ... 58458.html
OnlyMe
Approved Electrician
Has thanked: 225 times
Been thanked: 662 times
Post by OnlyMe »
When the RCD is off/tripped is there still power to the other sockets?
Return to “Electric Forum UK”
