Covering for wall cable
KarenCC
Has thanked: 18 times
Been thanked: 3 times
Post by KarenCC »
Hello
Would love some suggestions on this please.
A TV man has just run a TV cable to my kitchen. He offered the option of having it fitted to the skirting board - but said that they didn't do wall sockets. Though he could run the cable directly through the wall.
Unfortunately the skirting sticks out quite a way and so having it there does not fit with the furniture etc. So I asked him to put it through the wall directly. The hole is quite small but I would like to make it look a bit tidier. Has anyone got any ideas what I can buy to make it smarter. I was looking at something like this:
https://www.screwfix.com/p/labgear-whit ... lsrc=aw.ds
But I don't want to have to take the end off the TV aerial to attach it. I'm worried I won't get it back on correctly. I'm wondering if there is something similar that opens down the side and clamps back again, so that I can slot it onto the cable near the wall.
I've attached a photo so you can see what I mean.
Kindest
WhatsApp Image 2023-06-22 at 15.55.19.jpeg (70.67 KiB) Viewed 1010 times
Has thanked: 47 times
Been thanked: 2572 times
Fill the hole with a filler/caulk, it will also look less obtrusive than a "mushroom" Or buy one of the mushrooms and cut it down the side yourself.
KarenCC
Post by KarenCC »
Nice simple idea. I like it thank you!
ericmark
Has thanked: 116 times
Been thanked: 783 times
Post by ericmark »
I used LAP brushes in their grid switch system, the "mushroom" is really for outside so water drips away from hole. I just mix the brick dust with clear silicon and fill hole.
The brushes you mention would be of no use in this case as it would need a patress and would look silly in this case, and brick dust and silicone would be like underlining your nose with a moustache, the hole needs to be "hidden" not emphasised. Plain caulk can be painted over.
Return to “Electric Forum UK”
