Broken Myson MPRT
Dafttwat
Broken Myson MPRT
Post by Dafttwat »
Hello,
Went to replace the batteries on the hard-wired Myson MPRT downstairs and tried to fit it back in. Not sure exactly how it slots in, I’ve watched videos where it looks fairly easy but mine is a bit fidgety. Long story short I’ve snapped off one of the two metal prongs in doing so.
How screwed am I?
Plan on phoning Myson in the morning for advice/guidance, but thought I’d check in here what my options might be.
This type of thing is completely alien to me.
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Broken Myson MPRT
Post by aeromech3 »
Have you broken one of the four pins (two sets of two) that protrude out of the top cover circuit board, if so pretty much need a replacement unit.
Dafttwat
Broken Myson MPRT
Post by Dafttwat »
Yeah that’s exactly it. Only for like it’s only two pins at the top, and I’ve broken one of those. My unit doesn’t have two pins on the bottom.
Called Myson who suggested to try Wolseley. Seems like they don’t stock my unit and that it may have been discontinued as I can’t find it online.
Is this going to require a whole new system?
aeromech3
Broken Myson MPRT
Post by aeromech3 »
Have you the model number of your unit?
Wall thermostats are easily replaced.
aeromech3
Broken Myson MPRT
Post by aeromech3 »
A typical alternative would be Honeywell DT2 say £52 at Toolstation.
wine~o
Has thanked: 1415 times
Been thanked: 4030 times
Broken Myson MPRT
Post by wine~o »
aeromech3 wrote: Thu Oct 19, 2023 2:09 pm A typical alternative would be Honeywell DT2 say £52 at Toolstation.
Isn't the myson unit a standalone stat that transmits to a reciever connected to the boiler ??
aeromech3
Broken Myson MPRT
Post by aeromech3 »
w~o, Op stated it was hard wired!
Dafttwat
Broken Myson MPRT
Post by Dafttwat »
That’s everyone. Called Myson, apparently plenty still available but just now something that tends to be stocked by merchants. Have to be ordered in, so all sorted. Fingers crossed I can fit this one properly when I get it!
Daftwizz
Broken Myson MPRT
Post by Daftwizz »
Hi
Can you tell me where you found one? It’s Xmas and the kids have managed to break the Mprt can’t find d a replacement online.
Any help appreciated!
Merry Xmas!!
Has thanked: 48 times
Been thanked: 2604 times
Broken Myson MPRT
Daftwizz, :welcome: asking questions of posts you did not start (Hi-jacking) is not a good idea on any forum, not only is it bad etiquette, the question was asked over 15 months ago, and as is often the case, the Original Poster no longer posts (He only stayed for 4 days) so he will never read your hi-jacked post or answer it.
Best to start your own thread. :-)
