Downflow heater
jim1956
Downflow heater
Post by jim1956 »
Hi all
When wireing the downflow heater the y say to use a double pole switch ,would I have to put the cable coming from ceiling into the live and neutral on heater and would I have to put trunking to hide cable fom ceiling to top of heater
Thanks all
The white is the ceiling
Cheers
Has thanked: 48 times
Been thanked: 2604 times
Downflow heater
The use of a double pole switch is to isolate Live and Neutral at the same time (when the isolator is pressed.) So long as it is connected before the item it is to isolate it does not matter where it goes.
Trunking is your choice.
Neelix
Has thanked: 118 times
Been thanked: 218 times
Downflow heater
Post by Neelix »
What circuit is that connected to ?
Return to “Electric Forum UK”
