BOSS TPSE201 ?
jono4001
Has thanked: 2 times
BOSS TPSE201 ?
Post by jono4001 »
Hi guys looking for a bit of advice. Have had a new BOSS 181422 / TPSE201 Heating / Water programmer installed and want to just manually switch the heating / water on as and when required. Just can’t find how to do this as it would appear it’s looking for times to be set up for each day. Anyone with knowledge of this particular unit able to advise ? Thanks so much.
Has thanked: 47 times
Been thanked: 2575 times
BOSS TPSE201 ?
What does the manual say? (Brief instructions says to hold the HR+)
jono4001
BOSS TPSE201 ?
Post by jono4001 »
Someone-Else wrote: Sun Dec 17, 2023 6:30 pm What does the manual say? (Brief instructions says to hold the HR+)
Hi thanks so much for your reply. Yep noticed the HR+ mentions temp override but even after reading the manual still don’t see how to just have it set up to just switch on and of as required. Again it’s as if you need to input times for each day of the week ?!
BOSS TPSE201 ?
jono4001 wrote: Sun Dec 17, 2023 10:12 pmAgain it’s as if you need to input times for each day of the week
But you only need set it up once, either that or get a programmer you do like
jono4001
BOSS TPSE201 ?
Post by jono4001 »
Okay thank guys .
Has thanked: 820 times
Been thanked: 3519 times
BOSS TPSE201 ?
Does this help https://www.youtube.com/watch?v=Mv3lKkyyrrw (not watched it)
