Glow-worm Ultracom 35cxi - fitting Google Nest 3rd Gen
markymark74
Post by markymark74 »
I have a Glow-worm Ultracom 35cxi boilerand have bought a Google Nest 3rd generation stat.
I have attached an image of the current relay box installed.
Can anyone explain how to wire the Nest Heat Link to my boiler please?
Thanks in advance.
IMG_3235 Large.jpeg (190.11 KiB) Viewed 402 times
IMG_3233 2 Large.jpeg (217.13 KiB) Viewed 402 times
Has thanked: 48 times
Been thanked: 2605 times
markymark74 wrote: Sun Apr 21, 2024 1:56 pmCan anyone explain how to wire the Nest Heat Link to my boiler please?
Would help if you showed the terminal descriptions for the nest
markymark74
Thanks, please see attached.
I'm going to run the thermostat off the USB plug/wall socket.
Screenshot 2024-04-21 at 19.40.54.png (128.84 KiB) Viewed 387 times
Screenshot 2024-04-21 at 19.40.05.png (208.58 KiB) Viewed 387 times
