Staircase Reno (Novice!)
Evening all,
It's my first time posting here, so if I miss anything out please let me know.
Myself and my partner have just bought our first home together and we're looking to renovate our staircase.
We're hoping someone with some carpentry experience / knowledge may be able to help us out re a couple of things we're unsure on if possible please. Any input / advice would be really appreciated here, as it's our first 'proper' DIY project so to speak, and we really want to learn as much as we can so we get it right and looking good.
First of all, I've included a few photos. 1 shows the staircase as it was before, 1 shows it as it stands currently and 1 demonstrates a rough idea of what we're looking to achieve.
We'd like to remove the wooden slats / frame under the stairs that was previously supporting the dry wall. This is so we can expose the space completely and utilise it. However, we're unsure whether or not the slats that're in place are providing any support to the staircase or not. Given they're only thin, I thought it wasn't likely, but there is a long beam that sits on top of each of the slats, running from the bottom of the stairs up to the top. This is our first hurdle, we've tried to research but have limited results, I didn't want to just get hammer happy and rip it all out, just in case!
Secondly, the LH side of the door frame I didn't remove either, as it runs from the floor right up to underneath the top of the staircase / landing post. Again, I wasn't sure whether or not this was supporting anything.
Once this is sorted, I'm looking to install a new handrail, spindles and posts (again, first time trying), so if anyone has any pointers / tips on that topic too, please fire away!
Thanks for taking the time to read, if anyone could chip in and help you'd be doing me a massive favour and I'll likely get some brownie points off the Mrs!
Any questions or if more pics are required please let me know
Thanks in advance, Jord
- Example
- Example.jpg (105.84 KiB) Viewed 961 times
- Current
- 5.jpg (196.78 KiB) Viewed 961 times
- Previous
- 3.jpg (266.39 KiB) Viewed 961 times
- Landing
- 2.jpg (275.79 KiB) Viewed 961 times
