Gas Fire Replacement Project
Dec22
Has thanked: 2 times
Post by Dec22 »
Hi
New to forum, so hoping for some advice on a fireplace project - hoping this is right forum.
Gas fire removed by engineer. Purchased new electric stove.
Gap remaining - want to potentially cable fire in at opening, electrician due to view soon.
What to do with gap? Was considering filling with hardboard to exactly cover hole with a prop behind in case needed access in future, painting black and putting stove in front.
Do I need small vent at front? Anything up chimney such as insulation?
Any suggestions?
Complete novice so advice appreciated
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 566 times
Post by moderator2 »
Moved to General.
These users thanked the author moderator2 for the post:
Dec22 (Wed Sep 25, 2024 11:37 am)
Has thanked: 47 times
Been thanked: 2571 times
If you block the chimney you will get condensation. As its a chimney the top is open so a vent at the bottom would allow air flow, besides if you block it off, how will santa get down?
Dec22 (Wed Sep 25, 2024 1:54 pm)
Return to “General DIY forum”
