Help, my LG paint is grinning!
Piscator
Has thanked: 11 times
Been thanked: 1 time
Post by Piscator »
Hi everyone,
So far I’ve put 2 coats of Little Greene Intelligent Matt emulsion on my walls and as you can see from the photo there is grinning which from filler and Zinsser Bin.
What do you think I should do and should I carry on with a third coat?
LG citrine 71
LG citrine 71
toolbox
Has thanked: 131 times
Been thanked: 217 times
Post by toolbox »
Zinsser BIN is an excellent blocker but is known to "flash" more coats will solve it. :thumbleft:
Did you stir the tin fully right to the bottom of the tin?
dynamod
Elephant Man
Has thanked: 592 times
Been thanked: 1444 times
Post by dynamod »
Worth mentioning as well, that any emulsion over a shellac or alkyd stainblock, will take longer to achieve readiness to re-coat, as the water content has to dry outwards from these areas. Over other areas, some of the water content is absorbed, and it dries quicker.
It may have worked up and reactivated. This will destroy the opacity of the first coat.
Nihil expectore in omnibus
Puma
Has thanked: 681 times
Been thanked: 709 times
Post by Puma »
A dry absorbent base will grip paint a lot better than a waterproof one - in other words the first layer or two of paint when going over Bin will go on thinly.
