Vaillant vuw 202/3-5
Peter_1974
Has thanked: 1 time
Post by Peter_1974 »
Hi Guys,
I have a problem with my heating, I hope one of you will know the reason.
Everything is fine, it makes heat and hot water. But the pressure keeps rising. 0,1 bar in two or three hours. I have already replaced the filling valve but nothing has changed.
I have no clue what to check or change...
All ideas are very welcome!
Thanks in advance,
Peter
Has thanked: 831 times
Been thanked: 3627 times
The taps on Vaillant if plastic can allow the fill to contine as the tap handle turns but the shaft does not.Mine has the Vaillant metal ones. Take the taps off and turn the square valve shaft with a spanner as a first move
Peter_1974
Has thanked: 1 time
Thanks dewaltdisney,
it's plastic, and broken.... So I use a screwdriver :)
Anyway, thanks for the idea!
I am not an expert but rising pressure would suggest that the filling loop is open and your are probably discharging through the pressure release valve to keep it reasonably pressurised. All I can suggest is rechecking both the incoming and the fill valves again but I think you may be looking at getting Vaillant or a gas engineer in to sort it.
Peter_1974
Has thanked: 1 time
I think the same. The water goes into the heating circuit somewhere, so I replaced the filling valve. (I don't know if there is another place where the water can get in... )
Let us know how it turns out, it may help others :thumbright:
Peter_1974 (Wed Nov 13, 2024 7:15 am)
Peter_1974
Has thanked: 1 time
It seems, it is the plate heat exchanger. Not very cheap :roll:
Thinking about it, that seems logical. Sometimes, they can flush them out, but most fitters prefer to put a new one in. How old is the boiler?
Peter_1974
Has thanked: 1 time
15 years, or something like that. Can't remember
Get a repair estimate because at 15 years, it is near the end of the boiler's serviceable life, and the repair may only delay the inevitable. At least the repair money can go into the replacement. Get a loan and do it over 5 years, as the new Vaillant boilers have a five-year warranty. Around £75 a month I reckon but saving through better efficiency and no need for a maintenance plan other than a yearly service. Check out British Gas as they have low finance deals on when I last looked.
