Hi there
Any advice appreciated on this one:
I'm looking to replace a small radiator and the two valves on an upstairs radiator that is on a combi boiler system.
Q1 Do I need to isolate the mains water first? The access to turn off the mains has rather unhelpfully been covered over by some laminate flooring! If I power off the boiler is that sufficient for it to stop drawing in cold water?
Q2 Will I need to drain all the radiators before removing the valves? I've seen a couple of videos on YouTube of a single radiator being drained down and the valves being removed. In one of the videos only a tiny amount of water came out of the pipe feeding into the bottom of the valve once the valve had been removed but huge amounts came out in another video I watched (and I would prefer to avoid risking the latter approach).
- Ultimate Handyman Forum Index DIY Forum/Home improvement Plumbing Forum Central Heating & Boilers
- It is currently Tue Apr 01, 2025 3:22 am
Radiator valves
- Has thanked: 6 times
Malamute01
- Someone-Else
- Has thanked: 48 times
- Been thanked: 2604 times
Radiator valves
1) A combi boiler heating is a closed loop. That means as it says, it is closed and the water that is in the heating system never changes (Unless it is let out or a pipe / valve is damaged) So, no, no need to turn the water off.
2) As it is a closed loop (under pressure) if you take a valve off you will let most of the water out. (Vaguely like opening a shaken can of pop)
What you should do is find the lowest drain off point, and drain the system down so there is no water in the radiator you wish to remove. Below is a picture of a drain off valve
When you have done what you need to do, you then fill the heating system back up (Re pressurise it) you do this by opening the valves for your boilers filling loop.
3) You said your main stopcock is under some laminate floor. I would suggest you make an access panel soon, very soon, because sods law says you will get a burst pipe/large leak one day when you least expect it, and there will be nothing you can do to stop it as the stop cock is..........that is when you will wish you had made an access panel to the stopcock.
- beefburger.jpg (16.05 KiB) Viewed 283 times
- Malamute01 (Wed Nov 27, 2024 8:19 pm)
- Has thanked: 831 times
- Been thanked: 3627 times
Radiator valves
A combi system is a sealed system. The incoming water is only turned on via the filling loop under the boiler. There are two taps, and they are only used to fill or top up the system when needed. To replace the valves on your radiator, you will only have to drain down the system water level below the radiator. You can also look at using a temporary pipe freezing kit https://www.toolstation.com/arctic-haye ... kit/p11221 if there is room on the feed pipes
- Malamute01 (Wed Nov 27, 2024 8:20 pm)
- Has thanked: 145 times
- Been thanked: 129 times
Radiator valves
- These users thanked the author yartin for the post:
yartin
Malamute01
