Wiring double sockets
Malamute01
Has thanked: 6 times
Post by Malamute01 »
Hi there
Any advice appreciated on this.
I replaced a number of double sockets in a friend's house recently with double sockets that had USB ports. It was pretty straightforward as most of the existing sockets only required a maximum of two wires to be inserted into each of the connectors on the back of the new sockets.
But in one of the rooms there were three feeds as it were (in grey sleeving). One of those contained multi-stranded cable (for the live, neutral and earth wires) and the terminal on the back of the new sockets was nowhere near big enough to accept the multi-strand cable and two other cables into the same terminal.
Is there any way around this other than rewiring the room with modern wiring?
Many thanks.
Has thanked: 48 times
Been thanked: 2604 times
Remove the multi stranded cable. From your description it sounds like it is a small flex.
If there is a fault the circuit protection device (Fuse/mcb/rcbo) should operate. If there is a cable that is too small there is a chance the cable will overheat and start a fire.
It is probably too small in size to be protected by the circuit protection device, so if you don't connect it, there is nothing to be concerned about.
Malamute01
Someone-Else wrote: Tue Dec 03, 2024 10:24 pm Remove the multi stranded cable. From your description it sounds like it is a small flex.
Thanks for the reply.
Apologies if I haven't explained that very well. But I'm a little confused . . .
So, basically try wiring up the socket using the two twin and earth cables that DON'T contain the multi-threaded cable and then test it using a socket tester like this?
Screenshot 2024-12-03 at 23.12.16.png (404.1 KiB) Viewed 623 times
When you say "remove" the multi-strand cable do you mean just don't connect twin and earth cable containing the multi-strand cables and seal each wire off with electrical tape. I can't remove it because it is plastered into the wall.
Tape will come off over time, wagos would be better.
Malamute01 (Wed Dec 04, 2024 12:09 am)
Malamute01
OK, I'll give that a go. I used a couple of Wago connectors on some of the other sockets because the wiring had been cut way too short.
Neelix
Has thanked: 118 times
Been thanked: 219 times
Post by Neelix »
Randomly disconnecting cable’s often can have unexpected consequences
These users thanked the author Neelix for the post:
Malamute01 (Wed Dec 04, 2024 11:50 am)
Argyll
Has thanked: 1191 times
Been thanked: 583 times
Post by Argyll »
A photo would have been advantageous.
These users thanked the author Argyll for the post:
Malamute01
Argyll wrote: Wed Dec 04, 2024 8:52 am A photo would have been advantageous.
Good point. I'll take some pictures the next time I'm at my friend's house.
Malamute01
Neelix wrote: Wed Dec 04, 2024 7:39 am Randomly disconnecting cable’s often can have unexpected consequences
I'll try to get some pictures the next time I'm at the property which might make the situation clearer . . .
OnlyMe
Approved Electrician
Has thanked: 225 times
Been thanked: 664 times
Post by OnlyMe »
It does not sound like it's a small flex - if it was then there would be no problem fitting it in the socket terminals with the other two cables.
Scotty001
Has thanked: 26 times
Been thanked: 174 times
Post by Scotty001 »
If its just a case that the terminal space on the double socket will not accommodate 3 cores into each, would it be worth considering this double socket
MK K2747STWHI 2 Gang 13 Amp Rapid Fix Switched Socket
ericmark
Been thanked: 785 times
Post by ericmark »
MK sockets will take two 6 mm sq or three 2.5 mm sq cables, but other makes do seem to have smaller terminals. It is often a problem trying to take a spur from a ring final with small terminals on some makes. More than three wires in a terminal can mean one not clamped well enough, but a spur can only feed one socket or FCU, if using a FCU then that in turn can feed as many sockets as you like, as long as the loop impedance is within limits.
The tester shown does not test loop impedance,
this does, but it is a lot more expensive, working in your own house OK, but in someone else's house, you really should be testing, and complete the minor works certificate, basic to watch ones own back, I know you can cheat and put in figures which seem reasonable, but courts would not really expect anyone to fill in a minor works and not have actually tested, so if in the future something goes wrong, they are likely to believe you if you say it was OK when I tested it before leaving.
Return to “Electric Forum UK”
