Hi, I want to fix a metal handrail to an outside wall made of artificial stone. I want a very secure fitting of the brackets to the wall. I tried using the wood screws provided with regular rawl plugs but that's not strong enough. Can anyone suggest stronger fixers please? The brackets have 4mm holes (see image).
I thought about very long screws and wall plugs to increase the fixer friction. (I found 'cut to length' wall plugs on Amazon).
Or shield anchor expanding bolts. But I cant find any as small as M4 (though maybe the brackets would take thicker bolts if I drilled out the holes).
Also the artificial stone is very rough. What's the best way to deal with this to get the bracket in firm contact with the stone?
- Ultimate Handyman Forum Index DIY Forum/Home improvement General DIY forum
- It is currently Mon Mar 31, 2025 10:12 pm
Fixing Hand Rail to Masonry
spiderplant0
- Has thanked: 201 times
- Been thanked: 522 times
You could use all thread resined into place . I haven’t looked but I’m fairly certain you can get 4mm , I’ve definitely got some 6mm . With all thread you can drill a deep hole , fill with resin and push the bolt into it. Once set , which is really fast , fit your handrail brackets . Another advantage is that to overcome the irregularities you can place a nut behind the bracket to act as spacers where needed .
Grendel
- Argyll
- Has thanked: 1191 times
- Been thanked: 583 times
Make sure you clean out the hole first of any dust.Grendel wrote: ↑Thu Dec 05, 2024 8:05 am You could use all thread resined into place . I haven’t looked but I’m fairly certain you can get 4mm , I’ve definitely got some 6mm . With all thread you can drill a deep hole , fill with resin and push the bolt into it. Once set , which is really fast , fit your handrail brackets . Another advantage is that to overcome the irregularities you can place a nut behind the bracket to act as spacers where needed .
Argyll
Yes very true . That’s probably a case of taking it for granted that it’s an obvious step for the op
Just for reference I use something similar to one of these
https://www.lsengineers.co.uk/air-blow- ... gI-RvD_BwE
Grendel
Post by spiderplant0 »
Thanks for all the suggestions. In the end I used epoxy (Rawlplug R-KEM II Styrene-Free Polyester Resin) with M4 threaded rods. Found it a bit tricky to work with but the railing is now very firmly attached to the wall.
- PXL_20241230_102009623-small.jpg (190.78 KiB) Viewed 157 times
spiderplant0
- Has thanked: 831 times
- Been thanked: 3627 times
