Cat flap installation
Posted: Thu Dec 05, 2024 3:48 pm
by Ultimatejoiner
Really looking for feedback from you guys. Recently had these cat flap installed and I have been informed that this would be the standard and then obviously filled with Silicone.
Have a look at the photos and give me your opinion
Posted: Thu Dec 05, 2024 3:52 pm
by Someone-Else
It has been mounted on its side and the hole is too big, but that maybe because it is a replacement (Judging by the small round holes.)
Posted: Thu Dec 05, 2024 4:57 pm
by Ultimatejoiner
It is mounted correctly, just the way the photos has been uploaded
Posted: Thu Dec 05, 2024 5:37 pm
by Bob225
Looks like a used cat flap if it was new you would have both inner and outer parts - looks like its also missing its lock too
Installation isn't fantastic, looks like a cheap flap - staywell may some decent ones
Edit. It looks twisted, top left is pinched
Posted: Fri Dec 06, 2024 11:05 am
by Argyll
That's as rough as a junkies carpet!
I fitted one a few months ago. As I recall you trace around the cat flap and come in 11mm. That's the roughest job I've seen. They've totally f*ck your door. You'll need to get a proper joiner in to customise some kind of external trim to hide the gap.
Sack who ever fitted that. They haven't a clue what they're doing.
Posted: Fri Dec 06, 2024 11:29 am
by dewaltdisney
To remedy this using the cat flap you have it needs to be turned verticle. The gap will need to be adjusted using strip wood
https://www.diy.com/departments/smooth- ... lsrc=3p.ds which is not too thick and easily formed to form a subframe to set the flap in. The existing hole may need to be opened up slightly first.
Posted: Fri Dec 06, 2024 1:48 pm
by Bob225
dewaltdisney wrote: ↑Fri Dec 06, 2024 11:29 am
Rotate your monitor/screen
- rough flap.jpg (134.93 KiB) Viewed 90 times
- rough flap 1.jpg (140.81 KiB) Viewed 89 times
Posted: Fri Dec 06, 2024 1:53 pm
by Bob225
Wow that is rough
Posted: Fri Dec 06, 2024 2:07 pm
by dewaltdisney
Oh yes
The strip wood subframe would still work, a bit of paint to make good.
