Quartz halogen to led cooker hood lights
stevei
Has thanked: 94 times
Been thanked: 128 times
Post by stevei »
I want to change the two cooker hood lights from halogen to led. I propose to buy two led lamps and think I will need a new transformer. Just to verify this I have attached a photo of the existing transformer. Do I need a new transformer or will this one do for led's?
Has anyone any experience of doing this job?
Has thanked: 48 times
Been thanked: 2604 times
FYI: You can tell if a "transformer" is suitable for LED's or not by looking at its output rating.
If you look at yours it clearly says "lamp: 20-60W"
Which in plain engrish means the minimum lamp wattage must be 20w
As most LED Lamps are 5w each, what do you now think? (I am trying to teach you for your own future reference.)
yartin
Has thanked: 145 times
Been thanked: 129 times
Post by yartin »
Do you have 12V halogen bulbs now?
The output from transformer is 11.5V and 5A max, which gives the 60W max.
stevei
Post by stevei »
yartin wrote: Fri Dec 13, 2024 8:41 pm Do you have 12V halogen bulbs now?
Yes.
yartin
Post by yartin »
I think any 12V LED should work.
yartin
Post by yartin »
Probably halogen bulbs below 20W never existed at the time, hence the label.
yartin
Post by yartin »
Is it G9 or G4 type fitting?
yartin wrote: Fri Dec 13, 2024 8:44 pmI think any 12V LED should work.
Nope.
Someone-Else wrote: Fri Dec 13, 2024 6:32 pmIf you look at yours it clearly says "lamp: 20-60W"
stevei
Post by stevei »
yartin wrote: Fri Dec 13, 2024 8:49 pm Is it G9 or G4 type fitting?
G4
These users thanked the author stevei for the post:
yartin (Sat Dec 14, 2024 8:06 am)
ericmark
Has thanked: 118 times
Been thanked: 785 times
Post by ericmark »
You can now get power supplies rated from zero, this TLC - Premium Electronic Transformer ( 0w - 50w ) for example, just need to swap the transformer for a modem one.
Return to “Electric Forum UK”
