Upvc frence door repair
Retro_Popcorn
Post by Retro_Popcorn »
Hello all,
I'm new to this and looking to repair my french doors.
The top and bottom is damaged and letting in a draft
Believe the parts are called 'mullions' -these are cracked. They need to either be repaired or possibly the whole meeting point may need to be replaced.
Can anyone help
Has thanked: 48 times
Been thanked: 2604 times
As its cracked you can try and repair it, you may want to try sugru Click here it is a mouldable glue (quite good really) or find a local to you "window doctor" (As the name suggests, they fix windows, unlock them, change handles etc.) The glue will be cheaper and less hassle
Retro_Popcorn
That's great thanks
I'll give it a go :thumbleft:
Return to “General DIY forum”
