Connecting electrical wires after cutting
JordansDIY
Has thanked: 4 times
Post by JordansDIY »
I have had to cut some electrical wires as I had to do some floor joist repairs for my bathroom floor. I now plan to reconnect those electrical wires using Ideal 32A 2way push wire connectors.
As the wires are a bit short to reconnect, I am going to get some Prysmian 6242Y Grey 1mm² Twin & Earth Cable from Screwfix which I’m hoping is suitable.
I was wondering how do I find out which junction box will be suitable and compatible to put those connectors in considering it is a bathroom floor.
It is about a meter away from where the shower will be and a 22mm chipboard floor and also will be tiled over so not sure if that makes any difference.
Would appreciate specific product recommendations of what junction boxes I can use to make sure I get the right one.
The cables are for the kitchen lighting and some humidistat extractor fans for the bathroom and kitchen located below.
I live in Essex,UK and want it to be compliant and safe.
Massively appreciated,
Jordan
Has thanked: 48 times
Been thanked: 2604 times
Don't use ideal push fits, use wago lever connectors and a wago box.
I would use 1.5mm cable not 1mm
You will also need some earth sleeving.
Neelix
Has thanked: 118 times
Been thanked: 219 times
Post by Neelix »
Hager J804
Return to “Electric Forum UK”
