- It is currently Mon Mar 31, 2025 10:33 pm
Double insulated light with earth?
- Has thanked: 94 times
- Been thanked: 128 times
I've got a new light to fit and it is double insulated. It has a 4 way connector with Wago type on the input side, marked Neutral, Earth, Permanent Live and Switched Live. There is nothing connected to the earth on the light side, so why would it have the earth connector?
stevei
- Someone-Else
- Has thanked: 48 times
- Been thanked: 2604 times
For the definitive answer, ask the manufacturer why they gave it an earth terminal, anything else is a guess.
Neelix
- Someone-Else
No offence to Neelix, (or anyone else that replies) but that is my whole point, it is just a guess. It does not mean it is correct. If a reply said "because it is cheaper to use the same connector for all lights" would that have got a like? again it is just a guess.
- Has thanked: 118 times
- Been thanked: 219 times
Yes a guess a photo of the new light and the instructions might clear this upSomeone-Else wrote: ↑Sun Feb 16, 2025 10:29 amNo offence to Neelix, (or anyone else that replies) but that is my whole point, it is just a guess. It does not mean it is correct. If a reply said "because it is cheaper to use the same connector for all lights" would that have got a like? again it is just a guess.
Neelix
- wine~o
- Has thanked: 1415 times
- Been thanked: 4030 times
stevei, Frankly I'm suprised that no-one has given you the correct answer which is, in two words earth continuity.
Although the light fitting itself requires no earth, the integrity of the earthing MUST be retained.
So although that fitting may not require earthing the next light fitting along the circuit or the switch associated with that fitting may/probably will.
I'm suprised that neither Neelix nor S-E picked up on that.
wine~o
- ericmark
- Been thanked: 785 times
The regulations state "A circuit protective conductor shall be run to and terminated at each point in wiring and at each accessory except a lampholder having no exposed-conductive-parts and suspended from such a point." so to comply with regulations there has to be a terminal for the earth.
ericmark
I have fitted the light and I did connect the earth wire on the feed side. I understand the need for continuity of the earth on all circuits. I would normally make the earth safe within the fitting if no connection point was available. Thank you again to all for the answers.
stevei
