Can't type on facebook
Grendel
Has thanked: 201 times
Been thanked: 522 times
Post by Grendel »
I don't often post on facebook but earlier today I put a post on there. I used my phone as I was attaching a photo and all went well. This evening on the ipad I noticed so.e friends had replied so I in turn tried to reply to them . That's where I encountered the problem. When I tried to type in a response it deleted any letter as soon as I tried to put in another leaving only the last typed letter. I could still answer via the phone. I've tried logging out of facebook , refreshing it and turning off and on again but the problem has remained. Anyone with a bit more tech knowledge have any thoughts?
Has thanked: 48 times
Been thanked: 2604 times
Delete or back button pressed?
Grendel
Post by Grendel »
Doesn't seem to be . I'm largely a one finger typer so it's not as if I'm hitting anything elseat the same time. Also only affects facebook on the ipad as I'm typing this on it 🤔
Delete fb, switch off ipad, switch on, re install fb
Grendel
Post by Grendel »
Done all that no change , I'm a bit baffled to be honest...
Grendel
Post by Grendel »
Right I've had another play and have now got on to Facebook with f lite rather than the silk browser I was using previously and it seems to be working. Thanks for taking the time to answer.Irony is that this is the first time I've posted anything in nearly a year other than one post the previous week.
bourbon
Has thanked: 11 times
Been thanked: 19 times
Post by bourbon »
Glad you sorted it,
Return to “Computers”
