Wireless stat to rapid 32
Kevtr
Post by Kevtr »
I have just moved into a house that has a fairly new Intergas rapid 32 installed, it looks to me that it has never had a thermostat installed so perviously must have been controlled by the boiler panel. I am wanting to instal a salus wireless stat but the boiler terminals seem different than others I have installed these on.
Would anybody please be able to advise me if Using four core and earth would I put the live and neutral in with the existing live and neutral (2 & 4) or into 1 & 3 on the X 2 side?
Then would I be right in thinking the remaining two should go into 6 & 7 on the X 4 side after removing the link?
Neelix
Has thanked: 118 times
Been thanked: 219 times
Post by Neelix »
I think you need to consult a GSR
stevei
Has thanked: 94 times
Been thanked: 128 times
Post by stevei »
I would use 5 core heat resistant flex for the job, not 4 core and earth. The 6-7 is the volt free stat connection, confirmed by the link which is removed. Constant live and neutral, 2 and 4 as you have said.
Kevtr
Post by Kevtr »
Neelix wrote: Wed Feb 26, 2025 4:36 pm I think you need to consult a GSR
Thanks for the reply, if it was gas side I absolutely would, just thought I’d ask for advice on here as I’m in no real hurry to get it working
Kevtr
Post by Kevtr »
stevei wrote: Wed Feb 26, 2025 8:55 pm I would use 5 core heat resistant flex for the job, not 4 core and earth. The 6-7 is the volt free stat connection, confirmed by the link which is removed. Constant live and neutral, 2 and 4 as you have said.
Thanks for the reply, that is what i thought but the last image I uploaded seemed to suggest 1 & 3 for switch live and constant
stevei
Post by stevei »
Which stat are you going to use?
Kevtr
Post by Kevtr »
stevei wrote: Fri Feb 28, 2025 9:41 am Which stat are you going to use?
Salus RT510TX
stevei
Post by stevei »
The RT510TX is only the thermostat. You need the RT510RF for thermostat and receiver. According to the Salus website, this product is volt free so you would use 6-7 for the thermostat bit and 2-4 to power the receiver. Don't forget to connect the earth in the five core. As it relies on a wireless signal, I wouldn't position the receiver too close to the boiler.
Kevtr
Post by Kevtr »
Thanks for taking the time to look. The receiver that come with it is RXRT510, there is actually no earth terminal on the receiver so I assume I would just connect earth wire boiler side then terminate it inside the receiver. Instructions suggest installing it at least 1 meter from boiler so yes I’ve got plenty of space to do this.
stevei
Post by stevei »
Yes, terminate the earth safely in the receiver.
Kevtr
Post by Kevtr »
Thanks for your help appreciate it
