Manhole lifting tool for this
Zimzim
Has thanked: 31 times
Been thanked: 3 times
Post by Zimzim »
I've got a couple of these recessed manhole cover things in my garden. There's obviously a 'proper' tool for these, but lots of different types available for sale on screwfix on the like and I'm not sure which type works with this. The hole is 14mm diameter. Anyone know? BTW, one of the one of the other ones has locking buts or something in there, they've obviously been removed from this one (no need to locks them as they're in my back garden).
Has thanked: 48 times
Been thanked: 2604 times
Have you tried a "universal key"
You need two of them. You poke it between the "lid" and the "edge" lifting it up alternately a few mm at a time
Zimzim (Tue Mar 11, 2025 3:22 pm)
Zimzim
Post by Zimzim »
Someone-Else wrote: Tue Mar 11, 2025 3:13 pm Have you tried a "universal key"
<span class="skimlinks-unlinked">sd.jpg</span>
This is the technique I've been using, or thereabouts. I thought If I spent a few quid I might find something that means a bit less bending and, if I end up on my knees, the old man agony of lifting myself back up again! What I'm mainly trying to avoid is buying the wrong ones over and over and endless trips back and forth to DIY stores for refunds!
Has thanked: 831 times
Been thanked: 3627 times
It is probably a Lewis Pin lift. This will give you an idea to save me typing http://www.liftingpins.co.uk/product/lewis_pin
Return to “General DIY forum”
