- It is currently Tue Apr 15, 2025 8:29 am
condensation problem
Hi all,
This is my first post hope someone can help have read several topics and the advice is excellent.
Have just purchased a terraced property and have been advised that the damp patches on several walls are down to condensation.
The house has had a DPC done it would appear twice previously, the surveyor explained about salt in the re plaster attracting moisture he advised knocking off the plaster and replastering using washed sand and cement with a water proof additive.
Do I need to knock off all the plaster including the dry, I intend installing a positive pressure vent system in the loft and also venting the bathroom.
can the walls be Dot and dabbed using foam to adhere to the brick ?
cheers in advance.
Tim
cheers in advance.
Tim
Tim Robo
- Has thanked: 3 times
- Been thanked: 31 times
Hi Tim robo,
I would be inclined to use a dehumidifer for a few months ie 6 and also keep the house well ventilated ie leave windows open when able this will dry the house out and help the situation also it will keep the damp air to a minimum
leebwk
Tim Robo
Hi Tim robo,
Firstly do you have any guarantee's from the damp injection work ?, if so then maybe a call to the company and explain the situation as the DPC could be failing but if this has been done twice, i think there maybe an underlying problem causing this.
Knocking off the damp patches and replastering will only cause the plaster to become wet/damp again, you really need to knock off about 1200mm up from the floor and render using sulphate resisting cement with also a waterproofing additive then skim over the top.
leebwk
Hi leebwk,
No guarantees unfortunately, Am happy the problem is condensation as damp is too high for rising damp (surveyor) will knock off plaster to height recommended on walls affected by moisture - not just patch damp bits - using washed sand with additive and sulphate resistent cement and skim other walls. how does that sound ?
regards Tim
regards Tim
Tim Robo
Tim Robo
leebwk
- Has thanked: 29 times
- Been thanked: 2 times
I have a similar, problem I have been in my house about 15 months now and we noticed a serious amount of black mould had began growing behind a wardrobe and the bed (which was away from the wall). Also lots of mould in shoe cupboard etc, ie the winter stuff we havent looked at since last winter :(
The main problem is all on the first floor though, its a small house but we do dry the clothes indoors (we live in wet wales). There is lots of condensation almost permanantly in the upstairs windows.
I have just ordered a dehumidifier, and some mini rechargeable ones which I will put in the shoe cupboard etc. Im also painting the worst wall with an anti mould paint to try and hold that off from coming back
Do you think I should do anything else or look into anything else which maybe causing the problems?
the house was DPC and tanked a while ago before we bought it (still in guarantee)
Your help is much appreciated and has helped me to improve my skills
You can see the results of your help at
post494791.html
Thanks UHM.
post494791.html
Thanks UHM.
hotnuts21
leebwk
Cool, Yes we are trying to increase the air flow, the humidifier is going to be placed in the hallway which gets to each room, so hopefully it will also help a little with air circulation!
Weirdly we have old sash windows at the back and I always thought they were poor for insulation, but must be doing a good job.
I had a look behind the wallpaper last night and noticed its got a polystyrene backing paper, I presume some way to insulate against the cold!! Bit worried about whats behind that though!!
post494791.html
Thanks UHM.
post494791.html
Thanks UHM.
hotnuts21
