brick tiles......
brick tiles......
i mean the ones which are slices of real brick? as my new place is barratt-y n thus featureless, i plan to use these brick tiles on a lounge wall n in the opposite wall in the kitchen. not fancying mauling with pointing afterwards, i did a dummy run on a piece of plasterboard (which is what i will be sticking them onto in me new home). i used waterproof tile adhesive, spreading it all over a section then holding a tile in place till it gripped. the result looks really good, as the adhesive showing between bricks is beige coloured n i was worried that mortar might look to dark over a large area. i have made a smaller dummy wall and ensured it is fully sealed with tile adhesive, n when i shower, it showers too, as i plan to do a bathroom wall in this same effect. everything is well secured, so im wondering - what is the thing about pointing? any thoughts, please? and wd you suggest i panel pin the bricks to support them for a day or two in the lounge n kithchen? xx
