- Ultimate Handyman Forum Index TOOL FORUM Tool Talk
- It is currently Sat Apr 19, 2025 1:18 am
Nail gun
snakeeyes
- big-all
- Pro Carpenter
- Has thanked: 740 times
- Been thanked: 2355 times
heeelllooo and welcome snakeeyes
depends on your planned use!!!
you have light weight pin guns 18 gauge ideal for small mouldings t/g cladding and back pannels ect
you have second fix for skirting archatraves ect
and the biggies for studs ect
whats your budget and expectet use!!!
snakeeyes
- skiking
- Been thanked: 4 times
I went thought the same thought processes a couple of years ago (search on here and you might find my posts) and decided to buy a.......hammer
The cheap end and you are only looking at something to stick panel pins in which are easy to do with a hammer and then the £2-300 range if for the bigger stuff which I couldn't justify unless I was using it day in, day out.
skiking
- big-all
- Pro Carpenter
yep budget and first fix dont go together
you need 16 gauge as 18 is literaly pin size at around 1mm where as 16 is around 2.5mm or 5 times the size
i think you need to forget the studs and go for a second fix as a compromise but as said above 2-£300
i personaly only have 2 pin guns £30 arrow that fires up to 25mm pins
or the cordless ryobi at around £65 naked [without batts]that will do 32mm plus staples both great for txg cladding 'back pannels and light moldings
snakeeyes
- carhartt kid
- Has thanked: 3 times
- Been thanked: 1 time
Post by carhartt kid »
You can't get a nailer that does both 1st and 2nd fix! I went for the nailer that I would us the most! That was a Paslode 2nd fix.
If youre going to make a false ceiling. I'd use steel studding as its lighter and easier to handle. And you'll have to screw that together with self tappers/techscrews! Plus nails in a false ceiling will just pull apart, screws would be better if you stick with timber!
http://www.carhartt.com/
carhartt kid
snakeeyes
- Cellarman
I bought a Tacwise mains powered nail gun some time ago, but found that the recoil was so severe that unless I held the gun down with two hands, it would not drive the nails in properly. I have recently bought a pneumatic one and there is virtually no recoil and I can easily use it one-handed. It is a lot easier using the nail gun to put fasteners into awkward areas then using a hammer.
Cellarman
- apprenticejim
apprenticejim
- Pigglet
- Has thanked: 8 times
- Been thanked: 8 times
I've recently bought a Paslode IM65a after trying a tacwise OEL500. The tacwise was useless, the paslode is the badgers nadgers.
You get what you pay for I suppose.
Re expensive for DIY, the way I look at buying pro quality tools is that they will last a looooong time and are usualy repairable unlike cheap stuff.
I've also come to the conclusion that pro quality tools usually make the job a lot easier and enable a better end result. Even if I have to buy a new bit of kit to complete a job it usually works out cheaper than paying someone else to do it and I've then got the tool for next time
Well thats my list of excuses er I mean sound justification I use for convincing the missus I need a bit of kit
Pigglet
