new to site
A very warm welcome to the new members of the ultimatehandyman forum, you can say hello in here and tell everyone what you do and where you are from.
Locked
skinnyy21
new to site
Post by skinnyy21 »
hi just found this website thought i,de say hello.i,m in the wrexham area of north wales and i make laminate flooring for a living.love diy but never meddle with gas or electric(some things best left to those who know).i look forward to recieving and passing on any tips . :D
Has thanked: 1012 times
Been thanked: 918 times
Post by ultimatehandyman »
Hi Skinny21,
Welcome to the forum.
A laminate flooring expert is always welcome here, I look forwards to your input!
Thanks for taking the time to join the forum.
UHM
honeymonster
Post by honeymonster »
Hi Skinnyy21,
Welcome to the forum from honeymonster!
I have always wondered how laminate flooring was made, I don't suppose you could tell us how it is made?
skinnyy21
Post by skinnyy21 »
hi hm,laminate flooring is basically 3 sheets of paper and a 7 or 8 mm mdf board.the bottom paper is always brown and is used only to stop the board from bowing up when the resins dry out.the decor paper is patterned to look like wood panels or tiles as you know we then put a top layer of paper on which is like toilet paper and is loaded with resins and hardeners and soaked in aluminum oxide.its all sandwhiched together and run through a very hot press(about 210 degrees)for approx 14 secs it then goes to be stacked and has to be stored for 14 days before it goes to the cutting machine where its cut to the panels you buy in the shops. :D
RichieP
UHM Super Moderator
Has thanked: 4 times
Been thanked: 12 times
Post by RichieP »
You forgot to mention the steel reinforcement used in laminate flooring. I've been putting some down today and AI can't believe how quickly it blunts jigsaw blades. I ended up doing the last few with a hand saw, and even that ended up blunt!! Image
I often wondered why some laminate flooring caused sparks when cutting with my mitre saw!
Now I know why!
abi titmus
Been thanked: 1 time
Post by abi titmus »
Hi skinnyy21,
As you are such a laminate flooring expert I don'e suppose you would like to come and fit some for me?
:roll:
Locked
Return to “WELCOME”
