Please bear with me, this could be long!
Some background. The house is circa 1860. It is pretty solidly built but not from an era where damp proof courses were added. The walls are solid (ie no cavity) and thick. The floor is wooden, with quite a large space underneath before you get to earth. It has horse hair plaster of course!
the plaster around the living room window downstairs has come away from around the window frame in places, it is cracked. The window frame is wooden, set into the bricks and then plastered over.
The wood frame is dry, it doesnt smell, not dusty. The plaster was not mouldy and when whacked with a cold chisel and lump hammer, to take it back to where its still stuck to bricks, seems solid. Its been wallpapered, textured stuff you paint over, but this will be removed before redecorating.
The room doesnt smell "damp", even after time away in the winter.
So, do we have a problem?
