best silicone for granite
sparkydude
Has thanked: 2 times
Been thanked: 149 times
Post by sparkydude »
Hi all, had my worktops fittted by someone recently , they came back today to fit the upstands while i was at work, came home and they had made a right **** of the job, have removed them all myself, and will put them back properly this time. What is the best silicone to use to seal the joints and also to stick the upstands to the wall. The sealant i have been told is a neutral cure one, as it will not stain the granite just wanted to know if there was a specific best one to use.
Nick
panlid
Been thanked: 1 time
Post by panlid »
hi sparky. i have never done it myself but i have done a kitchen that had granite fitted. the guys just used clear dow corning sanitary silicone.
bstyle
Post by bstyle »
You are supposed to use a nuetral curing silicone for all natural stone, not many do and personally I've never had a problem using a standard silicone.
If you want to go the recommended route then Howtex stoneset silicones are all neutral curing
i fit
Post by i fit »
grip fill to the walls.
silicon between tops and upstand.
Oops, maybe not grip fill for granite (didn't see thread title :oops: )
Return to “Tiling Forum”
