Tiling over tiles - what to use?
Posted: Sat Jan 27, 2007 4:36 pm
by kiteboy
Hi all
Im just about to tile the bathroom in our first house.
We had to leave the old tiles on the wall (in parts anyway) as the tiles were bedded in concrete so almost impossible to remove
So we have now come to tiling over these tiles, I understand that normal PVA doesnt cut it so my question is should we just tile over using normal tile adhesive or is there special adhesive for this purpose
Any answers appreciated..........I really dont want these to start falling off in a year or two
Posted: Sat Jan 27, 2007 5:03 pm
by skiking
If you do a search you should find similar requests. I think you need to add sand to the PVA then apply to the tiles and let it completely dry before adding the new tiles. The experts will put me right if I've got it wrong
Posted: Sat Jan 27, 2007 5:25 pm
by -dj-
skiking those directions were for skimming over tiles, not for tiling over tiles, best wait for a tiler to comment as you said!
Posted: Sat Jan 27, 2007 5:45 pm
by ultimatehandyman
Normal tile adhesive will be fine, but you may struggle getting the new tiles level, if some have been removed.
When tiling onto tiles it is important to make sure that the joints on the new tiles do not line with the joints in the old tiles.
Tile on tiles
Posted: Sat Jan 27, 2007 5:55 pm
by skiking
thanks dj for putting me right....got plastering on the brain :oops:
Sorry kiteboy for the mis-info. :oops:
Posted: Sat Jan 27, 2007 6:04 pm
by ultimatehandyman
skiking wrote:thanks dj for putting me right....got plastering on the brain :oops:
You'll get used to being wrong, I did :sad:
I'm sure some people sit on here, just waiting for me to answer a post then they can add, "no that's not right, this is how you do it".
::b
It would make my life much easier if they would answer in the first place :roll:
At least you tried, it's the taking part that counts :thumbright:
Posted: Sat Jan 27, 2007 6:14 pm
by tim'll fix it
well you can buy adhesive for tiling over tiles. But normal stuff will work
however I have never understood why people dont just take the tiles off underneath
Posted: Sat Jan 27, 2007 7:33 pm
by kiteboy
Thanks for the replies guys
We would take them off, most we have however some are bedded in cement ie a partition wall which goes onto the bedroom............this is quite a thin wall
If we had hacked em off likelihood is it would crack the newly plastered wall in the bedroom
We have leveled everything off already so it looks OK
Just wondered about the tiles really
If we could get em off we really would
So normal adhesive should do the job ie good quaility Bal
Posted: Sat Jan 27, 2007 7:38 pm
by ultimatehandyman
BAL is used by many pro's and should be fine :wink:
Posted: Sat Jan 27, 2007 7:54 pm
by tim'll fix it
bal is good
I like cerafix from B&Q, never had a problem with it but never tried to use it over existing tiles
Posted: Sat Jan 27, 2007 8:22 pm
by bstyle
You can use any Bal adhesive apart from Single part flexible and Rapidset flexible, CTF3 and Rapidset can be used with an additive.
Basically all the ready mixed Bal can be used.
