Condensation problem on windows
sdowen
Post by sdowen »
I live in a two bed garden flat in London, which is the bottom half of a converted terrace house. I have a big problem with condensation in two rooms in the house with water running down the windows and doors and gathering on the woodwork and even dripping from the windows onto the floor and waking us up in the bedroom.
1. Front bedroom, two very large floor to ceiling windows which have double glazing but the seal may be broken as the double glazing is old.
2. Lounge at the rear of the property which has 3 windows and some double patio doors (no doubel glazing).
I have an internal bathroom with no window but have fitted a very powerful extractor fan.
I know new double glazing might solve the problem but is there anything I can do in the interim as I cannot afford new double glazing at the moment.
Any help welcome.
thanks
Simon. ::b
EJJ150847
Has thanked: 35 times
Been thanked: 188 times
Post by EJJ150847 »
Improve the ventilation and heating.
Condensation occurs where moist air comes into contact with air, or a surface, which is at a lower temperature.Warm air holds more moisture than cold air. When moist air comes into contact with a colder surface, the air is unable to retain the same amount of moisture and the water is released to form condensation on the surface.
John
Has thanked: 740 times
Been thanked: 2355 times
heeeelllooo and welcome simon :welcome: :welcome: :welcome:
you must ventilate with the door closed on the bathroom
you must also ventilate whilst cooking
other don'ts are
dont dry washing in doors
dont use parafin or bottled gas for heating
double glazing wont solve the problem it may just move it to the next coldest surface
as said above ventilation this may be acheived by vents or opening the room window for an hour or so immediatley after you turn the heating off in the morning
not nessiserily wide open but enough to feel the air flow
OnlineOnline
sdowen
Post by sdowen »
Thanks for the response here chaps.
I do open the windows when possible but am keen not to leave them open when not home for security issues and at night as our bedroom faces the road and there are noise issues.
I had thought about fitting an airbrick in the front bedroom as there does not seem to be one, either that or drilling some holes in the window and fitting some kind of sliding ventilation mechansim. Would this would?
Any thoughts welcome?
Thanks again
Simon.
you should only have to open windows for an hour or so in each affected room
you havent said if you indulge is moisture creating activities like drying clothes on radiators!!!!
OnlineOnline
sdowen
Post by sdowen »
Ok,
And yes we do dry clothes on radiators, just until the sun gets warm enough and we can dry them outside.
full load of washing 25=40p in the tumble dryer
maybe 1 to£2 a week for 12 weeks total cost £30!!!
consiquences
mold damp
possible repaint redecoration replaster :scratch:
providing extra ventilation will help but at greater heating costs because of extra heat loss :scratch:
OnlineOnline
clare123
Post by clare123 »
i have this prob
heeellooo clare123
let us know if the measures suggested dont work then we can try other solutions :thumbright:
OnlineOnline
