The efflorescence on two of our internal walls (the only original brickwork in a 19th century cottage) has been so bad that we have had one wall replaced completely and the other one has had a new membrane inserted. The first wall is no longer a worry, but the second still causes me some concern as some of the bricks are still very 'salty' - although I have chopped out the worst culprits. I have left the wall for several weeks without plaster, and have been using a dehumidifier to speed up the drying process, and it appears to be dry now, although the salts are obviously still there and visible on the surface of the bricks.
Is there anything else I can do to minimise the possibility of salt penetrating the new plaster when it is applied? I would have thought that drying the bricks would have been enough, but I am not 100% convinced. What about sealing with PVA for example, or using a salt inhibitor?
- It is currently Mon Apr 14, 2025 4:37 pm
Efflorescence
- Has thanked: 8 times
vicjay0147
leebwk
vespa
Re: Efflorescence
The best way to sort this problem out would be to dry line it.vicjay0147 wrote:The efflorescence on two of our internal walls (the only original brickwork in a 19th century cottage) has been so bad that we have had one wall replaced completely and the other one has had a new membrane inserted. The first wall is no longer a worry, but the second still causes me some concern as some of the bricks are still very 'salty' - although I have chopped out the worst culprits. I have left the wall for several weeks without plaster, and have been using a dehumidifier to speed up the drying process, and it appears to be dry now, although the salts are obviously still there and visible on the surface of the bricks.
vespa
Efflorescence
Post by vicjay0147 »
Thanks for such a quick response. Will dry lining with plaster board stuck directly onto the surface of the bricks be OK, or could the salt still mark the plaster/decoration. My previous experience with dry lining, when there have been concerns about continuing damp encouraging the salt, has involved leaving a gap.
vicjay0147
Re: Efflorescence
Refer to your previous experiencevicjay0147 wrote:Thanks for such a quick response. Will dry lining with plaster board stuck directly onto the surface of the bricks be OK, or could the salt still mark the plaster/decoration. My previous experience with dry lining, when there have been concerns about continuing damp encouraging the salt, has involved leaving a gap.
vespa
