dot and dabs wont dry
PETER R
Been thanked: 1 time
Post by PETER R »
had a kitchen reboarded all round , but on certain walls and after 3 coats of paint you canstill see where the adhesive was placed on the boards .
what can i do to stop this , and as ive mentioned in another thread should it have been battened
Gadget
Jack Of All Trades
Has thanked: 347 times
Been thanked: 344 times
Post by Gadget »
Is it a cavity wall where the problem is?
By eck! ©
PETER R
Post by PETER R »
the problem is on an outside wall ,one part just single brick like an out house , the other i think is cavity, but nothing outside just the neighbours back garden
theplasterersarms
Post by theplasterersarms »
could be a few things here
either cold damp walls transferring air/moisture through the dots
or possibly the wrong type of adhesive used to adhere the plasterboard,and the plasterboard has pulled the "oils" or WHY in the adhesive to the warm side of the wall.
