My 1930's house has a concrete plinth which runs round the property up to about 2ft.
Some of this is starting to come away, or has fallen off. I understand this is a "splashguard" for the lower part of the walls.
How do I go about repairing this?
Thanks in advance.
- It is currently Tue Apr 15, 2025 7:38 am
External render plinth
kregler
- ultimatehandyman
- Site Admin
- Has thanked: 1012 times
- Been thanked: 918 times
Post by ultimatehandyman »
Some pictures would be good
You could probably patch it up with a mortar mix, or a mortar repair compound. It depends how big of an area it is really.
If it is a large area, then mortar repair compound would work out expensive.
If using mortar, you could also add a waterproofing admix.
- Has thanked: 833 times
- Been thanked: 3636 times
What happens to these plinth renders in that there is no expansion gap built in. Water gets behind through cracks between the top edge and the wall and a good frost does the rest. Small natural structural movements can also help it on its way.
A batten is fixed to the wall top as a former for the top edge. If you cut an angle on the batten you could form a run off top edge. The mix is rendered on and leveled with a float or a gauge. If the wall is exposed I guess a bead of clear silicone along the top edge and wall may help stop water ingress.
Not sure of the mix ratios
leebwk
kregler
- Been thanked: 1 time
Post by theplasterersarms »
excellent advice but myself personally I would look at a polyurethane instead of a silicon caulk for the exteriordewaltdisney wrote:What happens to these plinth renders in that there is no expansion gap built in. Water gets behind through cracks between the top edge and the wall and a good frost does the rest. Small natural structural movements can also help it on its way.
theplasterersarms
